Cobb AP: Fuel Economy Map
Old Dec 6, 2009 | 03:27 PM
780's Avatar
780
I am planning on getting the Cobb AP for my stock Evo X. I had a question for those of you who are stock and running the Cobb AP with the Fuel Economy Map, what kind of mpg have you received? Noticeable difference? Driving experience?
Old Dec 7, 2009 | 08:26 PM
UntouchableEvo's Avatar
I don't know if anyone has tested this on a stock Evo however I do believe that people have had fairly good results with that map, it could also be the different mods made a difference too. I do hope someone with more knowledge can chime in...
Old Dec 7, 2009 | 08:44 PM
Clipse3GT's Avatar
From what I seen that mode basically turns your car into a sluggish turd by trying to keep you out of boost as long as possible.
Old Dec 7, 2009 | 09:48 PM
780's Avatar
780
I understand that it lowers boost considerably and if I was running on the fuel economy map traveling long distance highway or city driving would there be a large difference in mpg; the performance is not too much of an issue if I decide to use the map.
Old Dec 7, 2009 | 10:25 PM
Methodical4u's Avatar
I've asked several people about it, but there are people who are increasing their timing and getting better MPG.
Old Dec 8, 2009 | 11:27 AM
780's Avatar
780
That would require a custom tune and I am going to wait till I have more mods before I decide to do that. I would rather drive with the Cobb AP for the maps it comes with and was just wondering what kind of results anyone stock or close to it without a custom tune has been getting with the stock Cobb maps; i.e. the fuel economy map.
Old Dec 8, 2009 | 11:28 AM
xhomm02's Avatar
I have tried in summer Stage1 93 (no WOT, just cruising) on one way (100 miles) and Economy map on the way back and I had better results with Stage1 map. I do not remember the number but I remember it was so dissapointing that I decided not to use the economy map any more.
Old Dec 8, 2009 | 01:30 PM
goofygrin's Avatar
if you run the economy map make sure that you run GOOD gas. Guy locally with an STi got bad gas on the economy map and blew his motor. Cause? Correlation? Who knows. Just my experience. When I had my AP I never used the economy map.
Old Dec 8, 2009 | 03:16 PM
LaXGSR's Avatar
If I had to guess, I'd say the economy map probably tries to run more timing and less boost than stock. If you get bad gas, maybe on the STi it knocked too much. Just a wild guess...
Old Dec 8, 2009 | 05:02 PM
goofygrin's Avatar
that was our guess.
Old Dec 11, 2009 | 11:59 AM
terror75's Avatar
This might be part of this post. But I was reading in the other evo forums and they mentioned about a Mitsu ecu flash which gave them better fuel economy. from 24-25 on local and 28.9 on highway and it was covered in there warrenty. So, I was wondering if anyone in this forum tried it out? Well, it's not like the 2010 X is a gas saver now. haha
I wonder if all Mistu dealerships has the new flash map for our cars?
Old Dec 12, 2009 | 10:53 PM
780's Avatar
780
I probably will still go with the Cobb AP, however I will be a bit more careful with which map I am running. And terror75, if that is true I am definitely going to check it out.
Old Dec 13, 2009 | 02:26 AM
i'm no tuner dude... it's easy to change the timing and it's not dangerous at all.. you are talking about 2-3 degrees from 0-40 load. I did it and took a little ride to my Dad's house which my best mileage was 23.5 or so... changed the timing and as I pulled into his driveway it was right at 26.
Old Dec 13, 2009 | 02:29 AM
that's the first i'm hearing of 29 mpg on the highway, I find that hard to believe, they would have to SERIOUSLY lean the fuel out likely make all sorts of other adjustments as well.
Old Dec 13, 2009 | 02:51 AM
xRoguex's Avatar
you all are aware it says evo and not a prius on the trunk .....right?
