"service required" @ WOT after disabling asc
Old Jan 13, 2010 | 02:52 PM
tephra's Avatar
if its HBSpeed - then he doesn't disable the DTC.
he preferes to tune it out, looks like you just encountered some different conditions
Old Jan 14, 2010 | 02:46 AM
HB Speed's Avatar
Originally Posted by monkeywinky
fyi still cant get a hold of hb speed so i cant ask them directly - yet.
That is impossible...
i dont see a PM from you at all
or an email in our email box
Old Jan 17, 2010 | 08:21 PM
08 Evo X MR's Avatar
little different thing happened to me lately.
i just got tune by jestr yesterday and when i get on it, the car auto disables asc and says service required with the car swerving, it doesnt say service engine soon tho.
Any insight?
Old Jan 17, 2010 | 09:36 PM
XEVOX08's Avatar
I get this error also....weird would like to know why...
Old Jan 17, 2010 | 10:09 PM
Johnny Boy's Avatar
I only get it when i hit over 28psi. How do you diabel the DTC? Is it safe to do this?
Old Jan 18, 2010 | 05:52 AM
murlo26's Avatar
It typically only happens to people boost spiking near 30psi or plus.
I have not seen anyone hit this problem running 26psi or under. So usually people with upgraded turbos or peopleing running meth/e85 on the stocker have this problem.
In order to get rid of it the airflow/torque tables need to be adjusted.
Old Jan 18, 2010 | 07:35 AM
XEVOX08's Avatar
Murlo you might be right! After the bov change my car is hitting higher boost and close to 30psi. I have two knock counts and my a/f is perfect. I'm happy the way the car feels right now and will back it down one psi and run it on 29-28.
Old Jan 18, 2010 | 08:58 AM
murlo26's Avatar
Honestly if the bov is holding a couple more psi it would be safer to go get it put on the dyno for a few pulls to make sure it is dialed in right. A few psi spike could be devastating, unlikely but possible since you were tuned for a different boost setting(now the turbo doesn't have to work as hard since you are leaking to reach the desired boost levels).
Old Jan 18, 2010 | 11:36 AM
ScottSpeed21's Avatar
If you were tuned on the leaky stock BOV and then swapped to a valve that will hold the boost, you'll need to retune. Without a boost leak, there's a larger volume of air at lower temperature going into the engine than it's expecting.
Old Jan 18, 2010 | 03:58 PM
XEVOX08's Avatar
we street tuned it.....the car is running perfectly safe.
Old Jan 19, 2010 | 04:46 PM
monkeywinky's Avatar
Hey guys
First off HB, i didnt email you because i wasnt all that worried about it, i just called on monday and tuesday but got voicemail. Sorry for any confusion!
Old Jan 19, 2010 | 04:50 PM
HB Speed's Avatar
Hey guys
After we figured out the problem i SHOULD have come back here to update....my apologies everyone.
i was initially only getting the code on the freeway because i'd already be cruising at like 3.5k then punch it, causing my boost to hit about 30psi. i didnt notice in the mornings because the light on my boost gauge isn't plugged in...so i couldnt see it due to it being dark. but on my drives during the day i was able to consistently recreate this scenario. when pulling hard from a dead stop it was fine. I did an autocross on saturday with no problems at all. now that i know what the problem is, i just avoid overboosting.
ultimately, it was because i installed a testpipe without getting my car retuned.
Hey man if you wanna come in i can lower that spike a bit and help smooth it out for ya!
PM OR EMAIL us and we can take care of ya!
Old Jan 29, 2010 | 07:12 AM
marcinoctanex's Avatar
so here's my situation. i was driving yesterday and did 4th gear pull (about 200 miles after i switched fp relay) i have tp- back exhaust and filter mod tuned around 10K miles ago (spring)
while i was doing pull asc light came out + service required light. idk its b/c that was really cold yesterday or my fp relay was bad while i was getting tuned, anyway im getting bosst gauge asap!!!
Marc2192
Dec 4, 2016 03:25 PM
Illest92til
Sep 17, 2015 06:00 AM
jeffpinto
Apr 15, 2015 09:39 PM
hataeeun
13
Jul 11, 2010 11:58 PM
Mark Hubley
Apr 16, 2010 08:05 AM
