High IDC at 7k - stock turbo
Old Jan 14, 2010 | 04:07 PM
  #46
tephra's Avatar
the smallest amount possible, maybe 0.2 AFR in the map..
you will probably need todo at least 5 pulls before you start seeing the change.
as long as the cruise trim stays at 4% then thats ok, otherwise you will need to factor that in as well..
Old Jan 14, 2010 | 05:14 PM
  #47
GST Motorsports's Avatar
Scaling has nothing to do with the actual IDC calculation.
The calculation for IDC is:
rpm x IPW / by 1200
- Bryan
Old Jan 14, 2010 | 05:16 PM
  #48
tephra's Avatar
yeah there was always some contention on why IDC's could be greater than 100%...
Old Jan 14, 2010 | 05:54 PM
  #49
SiC's Avatar
SiC
From what I have seen, the numbers in Evoscan are way off for the IPW/IDC compared to ECUTek Deltadash. Evoscan always showed around 15% more IDC than ECUTek.
Old Jan 14, 2010 | 05:57 PM
  #50
tephra's Avatar
well IDC=RPM*IPW/1200 can't lie
Perhaps ECUTek factor in a 15% error to stop people asking questions?
Old Jan 14, 2010 | 06:09 PM
  #51
SiC's Avatar
SiC
Yeah, could be
Old Jan 14, 2010 | 06:40 PM
  #52
tsitalon1's Avatar
Tephra,
Small changes made, ~.2 (pushed the "[" key twice on selected items 180-320 7000-8000rpm.
IDC reduced slightly from 115 to 110-112.
Logs and screenshot attached
Old Jan 14, 2010 | 06:42 PM
  #53
Did the AFR stay the same or change? ( can't see the log right now )
- Bryan
Old Jan 14, 2010 | 06:53 PM
  #54
tsitalon1's Avatar
- Bryan
Hard to say Bryan, if it changed, it didn't change much. I'll have to wait until you can see the logs.
Old Jan 14, 2010 | 07:00 PM
  #55
Just looked. AFR looks the same if not richer.
Keep leaning out the fuel map.
- Bryan
Old Jan 14, 2010 | 08:15 PM
  #56
tephra's Avatar
[ or ]?
which is leaner? lol
just keep going until the afr starts leaning out - then report the IDC back.
its starting to sound like a bad pump
Old Jan 15, 2010 | 01:39 AM
  #57
E6-X's Avatar
finally i get some reading on IDC guys, but it's weird numbers ....
i;ve put in function in evoscan for idc = 31.25*x*x/1000*x/1200
maybe i'm inserting the wrong formula ???
Old Jan 15, 2010 | 02:00 AM
  #58
tephra's Avatar
yeah thats wrong...
it should be something like [RPM]*[IPW]/1200
Old Jan 15, 2010 | 02:45 AM
  #59
E6-X's Avatar
tried that didn;t work. had to use numbers instead of [RPM]*[IPW]/1200.
i'll give it another shot.
thx tephra finally u are here to save me again ! weeeeeehhhhhoooooooooo
Old Jan 15, 2010 | 05:33 AM
  #60
tsitalon1's Avatar
[ or ]?
Opps yeah I mean "]" leaner.......
I don't have my logs with me and can't upload them now due to company policy, but I leaned the map some more this morning. I leaned 6500-8000rpm 180-210 load cells by another 4 steps.
So now, the fuel map from 6500-8000 rpm should be roughly .6 A/F leaner..
I made one pull and plan to make a few more for you, but initial logs indicate its leaning out a bit. I actually saw 11.6 in the log this time.
I'll upload logs as soon as I get some more pulls after work, unless I get arrested for all this damn "tuning"
