Logging with the (Beta) Standalone Tactrix Cable Logger (No More Computer!)
Old Oct 18, 2012 | 08:35 AM
  #196
TravisF's Avatar
Originally Posted by Windstorm
Can anyone tell me the address to log STFT on 2008 USDM GSR (52680022)?
(the one from the cfg files a few posts up results in no data)
TIA,
http://www.goldenevo.com/logx_view.php?ecu=3
Old Oct 18, 2012 | 06:32 PM
  #197
Windstorm's Avatar
Thanks, found it! Below if anyone else is looking:
paramname=STFT
paramid=0x808898
scalingrpn=x,0.1953125,*,25,-
Old Oct 19, 2012 | 06:53 AM
  #198
Live4Redline's Avatar
Originally Posted by richardjh
No, it's just that you exceeded my maximum-questions-per-post-limit-before-my-brain-explodes... by eight.
Rich
Lol. What can i say, i like to come prepared and after reading 13 pages of back and forth posts... they rack up pretty quickly.
Thanks again guys, got this up and running like a charm. Its nice to be able to log track heats for review the next day. Not only from a performance and safety stand point but logged MPH is kind of nifty to review and go back on during the Go Pro Vids. Peak MPH in straights and average mph per run, now if only i could find a way to log G-Force off the ACD controller! =)
Old Oct 22, 2012 | 11:59 AM
  #199
fostytou's Avatar
EvoM Community Team
There is a way to for the CT9A. That probably requires a laptop and is for another section though.
Old Nov 28, 2012 | 07:24 PM
  #200
acidtonic's Avatar
I just picked up an OP2.0 for my 2012 X and I'm looking to log my Zeitronix ZT-3 through standalone input.
1. Has serial logging been implemented yet for this wideband on the mini jack?
2. If not, has anyone already done the work for scaling the Zeitronix Wideband for analog input by chance?
If not, I'll just log raw voltage on Pin 8 using a small OBD2 extension cable and scale it properly using the manual which specifies the scaling and post back.
Can't wait to get this working. I'm going to use standalone logging from the beginning on the X. I was so tired of the whole laptop in the car thing with the IX.
Thanks for your help guys
Old Nov 29, 2012 | 09:38 AM
  #201
fostytou's Avatar
EvoM Community Team
I think it should work for any serial data stream - should be no scaling required.
Old Dec 1, 2012 | 07:02 AM
  #202
acidtonic's Avatar
It would be fantastic if that is the case. I thought the serial communication was proprietary to each manufacturer and not an open spec.
So the LC-1 would speak a different ASCII output than the Zeitronix unit if you were to capture the stream of communication.
I know the Analog input through pin-8 will work since voltage is voltage, but I'd rather not splice into any wires if I can just get a female RS-232 to male 2.5mm cable and hook it up.
Can anyone else confirm this with Zeitronix units?
Old Apr 27, 2013 | 06:16 PM
  #203
Its been awhile but just wanted to note that this is still up and working great on my Evo 9. Every so often i take a look at the logs to make sure everything is still running great and its absolutely amazing for recording track info.
Someone was asking if I could post my CFG files up so here ya go.
EVO 9 FILE BELOW (with AEM Wideband connected via mini-jack and 1 Byte load)
; LIVEREDLINE'S Evo 9 LOGCFG FILE v2.2
; must be named logcfg.txt and be placed in the root directory of the
; microSD card inserted in the openport in order to work
; this uses the MUT-II protocol over the K-line, which works
; for many mitsubishis, including the EVO 8 and 9
;----------------mut2----------------
type=mut2
paramname=TPS
paramid=0x17
scalingrpn=x,0.39215686,*
paramname=RPM
paramid=0x21
scalingrpn=x,31.25,*
;paramname=2ByteRPM ;<-- Disabled in exchange for 1Byte Load
;paramid=0x808746
;databits=16
;scalingrpn=x,3.90625,*
paramname=TimingAdv
paramid=0x06
scalingrpn=x,20,-
paramname=Airflow
paramid=0x1A
scalingrpn=x,6.29,*
paramname=Speed
paramid=0x2F
scalingrpn=x,1.242742384,*
priority=2
;paramname=Gear ;<-- Works but Disabled
;paramid=0x80886e
;databits=16
;scalingrpn=x,22.6,/
;priority=2
paramname=MAP
paramid=0x38
scalingrpn=x,1.25,*
paramname=KnockSum
paramid=0x26
;paramname=AFRMAP ;Testing *FAILED (Does not work)
;paramid=0x8088f5
;scalingrpn=x,1881.6,/
;paramname=AFRMAPxTEST ;Testing *FAILED (Does not work)
;paramid=0x32
;paramname=LoadCalc ;<-- Disabled in exchange for 1Byte Load
;scalingrpn=0
;paramname=ECULoad ;<-- Disabled in exchange for 1Byte Load
;paramid=0x1C
;scalingrpn=x,0.625,*
paramname=Load1Byte ;<-- WORKS
paramid=0x41
scalingrpn=x,1.2,*
;------BOOST CONTROLER STUFF------
paramname=ActiveWGDC
paramid=0x808b53
scalingrpn=x,0.5,*
paramname=BoostError
paramid=0x808B50
scalingrpn=x,128,-,2,/
paramname=WGDC_Correction
paramid=0x808b51
scalingrpn=x,0.5,*,64,-
paramname=PassiveWGDC
paramid=0x80a53f
scalingrpn=x,0.5,*
paramname=LoadFuel
paramid=0x80876E
databits=16
scalingrpn=x,.3125,*
;paramname=IATS ;<-- Works but Disabled
;paramid=0X808659
;scalingrpn=x,1.8,*,40,-
;---------FUEL TRIMS--------------
; ORGNINAL MATH =x,0.19607843,*,25,-
; EVOSCAN MATH =x,0.1953125,*,25,-
paramname=FuelTrim_Low
paramid=0x0C
scalingrpn=x,0.19607843,*,25,-
priority=2
paramname=FuelTrim_Middle
paramid=0x0D
priority=2
paramname=FuelTrim_High
paramid=0x0E
paramname=FuelTrim_InUse
paramid=0x50
priority=2
paramname=O2Feedback_Trim
paramid=0x50
priority=2
;-----------TRIGGERS------------
;----Only log when engine is running----
conditionrpn = RPM,0,>
action = start
conditionrpn = RPM,0,==
action = stop
;-----------WIDEBAND------------
;---AEM via OP2 Jack---
type=ascii
paramname=WidebandAF
paramid=1
----------EXTRA----------------
type=calc
paramname=LogEntryDate
scalingrpn=0
paramname=LogEntryTime
scalingrpn=0
paramname=LogNotes
scalingrpn=0
paramname=Custom
scalingrpn=0
Log file example...
Old May 4, 2013 | 12:50 PM
  #204
Kakihara's Avatar
thanky ou very much live4redline I just bought a 2.0 and only stumbled on evoX threads since 2.0 users are mostly evoX, I drive a 9 with tephrav7
gonna take your logcfg as a base and then modify it a bit ,got a lc-1 and I will make a cfg mostly for virtual dyno runs maybe TPS >95% start TPS < 95% stop
will make a post in the 9 section when I'm done, thx again
Old May 4, 2013 | 01:13 PM
  #205
Not a problem and any time boss. For best results limit the items you log to the bare minimum. A lot of the stuff i log i turn on and off for different results as you can see in the file.
Old Jul 31, 2013 | 04:42 PM
  #206
TrailBrake's Avatar
If someone could kindly share a logcfg.txt file that works correctly 2013 RA it would be greatly appreciated, as I would like to validate everything is alright with the GST basemap V31.003 (stock pill: 93 octane) that I installed today.
Of the parameters I have tried, the following seem to be the most incorrect based on what I am seeing in the output file:
paramname=RPM (VALUE DOES NOT CHANGE FROM 722)
paramid=0x808794
databits=16
paramname=Knock (DISPLAYS EITHER 1, 8 or 16)
paramid=0x808A9B
paramname=Timing (VALUE DOES NOT CHANGE FROM -20)
paramid=0x808A57
scalingrpn=x,20,-
Any help would be greatly appreciated.
Thanks.
Old Jul 31, 2013 | 09:44 PM
  #207
paramid=0x808794
databits=16
paramid=0x808A9B
paramid=0x808A57
scalingrpn=x,20,-
Thanks.
Have you given these a try yet? Edit: Probably won't work for an Evo X, my bad.
paramname=RPM
paramid=0x21
paramname=KnockSum
paramid=0x26
paramname=TimingAdv
paramid=0x06
scalingrpn=x,20,-
Old Aug 1, 2013 | 12:57 PM
  #208
TrailBrake's Avatar
I will give those a try, thanks.
Any hints on collecting boost in PSI or manifold pressure in kPa?
Have you given these a try yet? I think you'll have better luck if you do.
paramname=RPM
paramid=0x21
paramname=KnockSum
paramid=0x26
paramname=TimingAdv
paramid=0x06
scalingrpn=x,20,-
Old Aug 1, 2013 | 02:31 PM
  #209
Boost and Manifold pressure are the same thing. You also did not specify what MAP sensor so heres two options that i haven't tested but an educated guess says they should look something like this...
Edit: Again probably won't work for an Evo X.
JDM 3BAR Map Sensor (Pretty sure its the same as stock Evo X sensor)
paramname=Boost (JDM 3BAR)
paramid=0x38
scalingrpn=x,0.19348,*,14.5,-
OMNI 4BAR Map Sensor
paramname=Boost (OMNI 4BAR)
paramid=0x38
scalingrpn=x,0.2369,*,14.5,-
*Note that if you changed the above 14.5 in Evoscan to your local atmospheric pressure, you then will need to do that here as well.
Old Aug 1, 2013 | 03:22 PM
  #210
paramname=RPM
paramid=0x21
paramname=KnockSum
paramid=0x26
paramname=TimingAdv
paramid=0x06
scalingrpn=x,20,-
paramid=0x38
paramid=0x38
^ Should work on Evo IX.
But I forgot that the Evo X does it a little differently. May need to try this if you have an Evo X instead...
paramname=RPM
paramid=0x808746
paramname=KnockSum
paramid=0x808A4B
paramname=TimingAdv
paramid=0x808A07
scalingrpn=x,20,-
paramname=Boost (STOCK 3BAR)
paramid=0x80871A
scalingrpn=x,0.04824345,*,14.5,-
;*Note: I dont like these scalings but thats what was listed. If it doesnt read right maybe try the "x,0.19348,*,14.5,-"
paramid=0x80871A
scalingrpn=x,0.058575,*,14.2,-
;*Note: I dont like these scalings but thats what was listed. If it doesnt read right maybe try the "x,0.2369,*,14.5,- "
