ASC / 4WD / ABS Service Required
Old Apr 17, 2010 | 10:10 AM
LaXGSR's Avatar
Originally Posted by bryanlo
thanks for the info lax, is this something I should have the dealer do? or do i have my mechanic do it?
Unless your mechanic has a mitsu MUT3 scan tool, they won't be able to do it. You will most likely have to go to the dealer to get them to bleed the ACD.
Old Apr 17, 2010 | 10:16 AM
bryanlo's Avatar
oh i see..what should i tell them? to still get it done under warranty considering i put an after market clutch outside of mitusbishi.. lol i'm really dumb when taking the car in to mitsubishi..hehe
Old Apr 20, 2010 | 08:40 PM
zerocooll21's Avatar
South Coast is awesome, nothing but good service all the way around.
Old Apr 20, 2010 | 10:26 PM
bryanlo's Avatar
my mechanic bled my line and the light stayed but disappeared overnight..perhaps ecu just needed to forget.
Old Apr 24, 2010 | 01:46 AM
EVO X 6950's Avatar
I had the same problem come up after a clutch install. my ASC service required and S-AWC service required light came on after driving it a couple of miles after getting out of the shop. I'm not sure what happened but i'm almost sure mitsubishi wont cover me since i'm droped on coilovers and installed a clutch. have you fixed your problem yet? I would like to know what went wrong.
Wow samething just happened to me today
Old Apr 24, 2010 | 04:01 AM
DarwinX's Avatar
The moral of this story is if you take your Evo off-road, drive it through a car wash before taking it to the dealership.
Old Apr 24, 2010 | 12:31 PM
EVO X 6950's Avatar
how long did you drive with it on?
Old Apr 24, 2010 | 12:45 PM
EVO X 6950's Avatar
this is exactly what popped up after the clutch install
Attached Thumbnails ASC / 4WD / ABS Service Required-img0953.jpg
Old Apr 24, 2010 | 01:05 PM
EVO X 6950's Avatar
edit: just checked the reservoir tank in the trunk and almost empty, heading now to the dealership to get some atf sp 3
Old Apr 24, 2010 | 02:35 PM
EVO X 6950's Avatar
just got back and it worked $10 for a quart
gotta love EVOM
Old Apr 25, 2010 | 12:49 AM
bryanlo's Avatar
I drove it for a day with the light, bled it again the next day and light was still on, turned the car on the next morning and the light was gone.
Old Oct 4, 2012 | 12:58 AM
evox23's Avatar
Any updates on this? I have aftermarket clutch as well like 1k miles and got this codes. Do I have to visit dealership or bleeding the acd will fix it?
Old Oct 4, 2012 | 09:44 AM
drew08's Avatar
Result
Sorry for not updating, but the issue was caused by a broken yaw rate sensor. I ultimately brought it into South Coast Mitsubishi and they quickly diagnosed the problem. Sadly I had to pay for the replacement part because I was out of warranty but they were nice to charge me nothing for labor.
Old Oct 4, 2012 | 05:10 PM
evox23's Avatar
thanks for the update, i have read so much already and decided to set an appointment as well to the dealership to get diag, and im almost sure my steering angle sensor is bad...but i hear some faint cracking noise somehwere in the steering wheel...fyi i have aftermarket steering wheel installed with boss kit and quick release.
Old Nov 10, 2012 | 03:44 AM
kuz120fq360's Avatar
Hi
i have an evo x suddenly the car battery when off!
when i started the car with one other car i took it for a ride and started showing in the dash the following
service required
abs warning light
afs warning
the abs doesnt working at all
and the battery is completely dead!
has anyone the same problems!
thanks and sorry for my english!
THANKS
