ASC / 4WD / ABS Service Required
Yes, and I suspect once you sort out your battery the lights will go off. At least the ABS light will and your ABS will work. The other lights should as well as I suspect they are on due to the bad battery, otherwise you may need a Cobb AP or similar to clear the codes.
I'm running a stock 2010 EVO X GSR with less than 6,000 miles. Three days ago the following warnings show up on my display while I'm minding my own business driving on the freeway to work:
ASC Service Required
4WD Service Required
ASC OFF
I take it to the dealer as it is still under warranty. They pull the fault codes (there are 9 apparently). They tell me that the battery is bad. After they replaced the battery, 5 of the faults went away leaving the following 4:
U0125 - Sensor cluster CAN timeout
U0251 - AWC CAN(local) timeout
C1290 - Fail safe mode(Lost of CAN data)
U1003 - Sensor cluster Bus-off
Has anybody experienced anything similar? Any ideas? Appreciate any help.
ASC OFF
lespotts
25
Jul 31, 2020 01:08 PM
daasca
May 16, 2016 05:08 PM
