Rev hanging
Old Mar 22, 2010 | 04:59 PM
EVOxStuntin2008's Avatar
Rev hanging
08 gsr Cobb ap stage 2, injen intake w/uicp, Megan cb, mxp resonated tp. Never thrown a code, but I've noticed that sometimes when I run through a gear and redline I will let off the gas the revs will hang at redline until I engage another gear. Typing on phone sorry
Old Mar 22, 2010 | 05:16 PM
MR. EVO MR's Avatar
Maybe clutch?
Old Mar 22, 2010 | 05:22 PM
Rome-Evo's Avatar
maybe your throttle is sticky...did u check your cable.? or tps...
Old Mar 22, 2010 | 06:01 PM
turbo26tsi's Avatar
Veteran: Air Force
no cable on evo x's, try resetting by removing the battery.
Old Mar 22, 2010 | 08:40 PM
Will try
Old Mar 22, 2010 | 09:00 PM
Golden's Avatar
Probably just too much fuel in there.
Old Mar 23, 2010 | 04:35 AM
prodigy1210's Avatar
Sticky throttle blade.. You are not running a catch pan i presume and the PCV will take a dump all over the throttle over time.. How many miles do you have?
Old Mar 31, 2010 | 08:52 AM
Little over 7k
Old Mar 31, 2010 | 09:03 AM
tonyboy's Avatar
did you have your car tune or did someone touch the maps for electronic throttle? that would be my guess..but regardless, evo x tend to rev hang...if it does that, try stepping on the clutch it will kill the rev hang..
Old Mar 31, 2010 | 10:16 AM
churbo's Avatar
yeah i've seen that before and if you tap the clutch it'll go back down....it also is a sign of a clutch going bad.
Old Mar 31, 2010 | 12:05 PM
evolution2186's Avatar
I've had this problem many times just as many evolution 8 owners have "I know you have an 08".
#1 Cause= Carbon build up in and around throttle body. Clean and re-lubricate.
#2 Cause=Adjustment of throttle
Old Mar 31, 2010 | 03:25 PM
Golden's Avatar
nm
Old Apr 1, 2010 | 04:49 AM
That's what she said .. Sorry I had to
Old Apr 1, 2010 | 05:50 AM
AWDTerror's Avatar
Rev hang is a common problem on Evo Xs, even stock, some how though a tune seems to exacerbate the problem, search and you will find plenty of threads. Mine does it as well, it's pretty annoying.
Here is the big thread on it: https://www.evolutionm.net/forums/ev...hang-tune.html
Old Apr 1, 2010 | 02:30 PM
kmart888's Avatar
Shoulda got an MR! (Sorry I had to)
