P0133!?!?!?
Old Mar 25, 2010 | 11:29 PM
HR2L's Avatar
P0133!?!?!?
Got this today? Should I be concerned? Usually get P0140, but this came along with it tonight...
Starting to get sick of all the SES i've been getting with the X?
Any insight would be great. Exhaust leak maybe?
Old Mar 25, 2010 | 11:55 PM
tephra's Avatar
DTC P0133: Heated Oxygen Sensor (front) Circuit Slow Responce
Front 02.. Not Rear02
I would be concerned...
What exhaust mods have you done recently?
Old Mar 26, 2010 | 12:11 AM
HR2L's Avatar
Tephra,
I run a Long o2 DP from Ultimate racing as well as RRE Rally TP and Ultimate racing catback (TBE). I also run an ETS Exhaust Manifold. All these were done quite awhile ago (Dec, January time). All gaskets were replaced @ that time as well. Should I baby the car for a bit until I can have it looked at? This is the first time I've thrown this code. Im tuned by Bryan@GST.
This is starting to erk me with all the SES's i get with my X. Never had any issues with my STI, and it was just as built as my X's is now...
Old Mar 26, 2010 | 01:13 AM
tephra's Avatar
check that the dump isn't leaking...
clearly the STI is a better car
Old Mar 26, 2010 | 02:57 AM
livevil's Avatar
How do you check if your dump is leaking ?
Old Mar 26, 2010 | 04:37 AM
tephra's Avatar
look for soot marks around joins or on the chassis...
get a stethescope and listen around joins while the car is running...
Old Aug 28, 2013 | 07:13 PM
siang004's Avatar
had check exhaust leak,wiring,conector n replace a new o2 sensor,but still get the same code,some time the code will shut off it self,please help~~
Old Oct 10, 2020 | 04:37 PM
jrezzy's Avatar
Hi Tephra!
I'm getting the same code on my X. I replaced the front O2 today with a Denso 234-4116 (which i believe is what comes stock) and had to code come back within 45 minutes of driving. All I have on the car is an aftermarket intake, 1000cc injectors and an ecu flash (Tephra tune). Thankfully I was able to pass inspection last week due to the genius of some Evo guru(s) out there
It's a bit concerning how lean the afr gets during idle though. The car leans out the a point where it wants to die or actually stalls. While driving things seems fine, but at a stop it's a gamble. I'm not sure to where to look next as i've been digging through the forum posts and have seen similar problems but no verified solution. Maybe exhaust manifold leak? Maybe crappy aftermarket intake? who knows..
I have a more detailed forum post here: https://www.evolutionm.net/forums/ev...l#post11920250
Any of your guru insight would be greatly appreciated!
Havoc86
Lancer Troubleshooting
Dec 5, 2013 07:56 AM
ThugzNHarmony
Jan 14, 2013 09:40 AM
dahuii77
Oct 7, 2011 12:21 PM
mr2driver
Aug 14, 2011 08:25 AM
8-BallEvo
Aug 3, 2010 07:55 PM
