FIC 1100's Experience?
Old Dec 15, 2010 | 12:34 PM
  #136
scheides's Avatar
EvoM Moderator
Originally Posted by mrfred
I haven't noticed any difference over stock injectors, but the 4G63 is pretty noisy. I don't think you'll find a bad review on the FIC1100s. Looking at your BBX dyno chart, it looks like your Evo is making power out to 7800 rpm. Based on dyno numbers and IDCs from my setup, the FIC1100s should support about 500-520 whp DJ (90-95% real IDC) on E85 with your setup.
Yea, I might just go with the 1680s if I ever upgrade from the 800's. I'm sure they will be maxed out on my new setup on pump gas (was at 97% peak idc before)...520 on e85 eh? I wonder what they would do with that new DW300 pump behind them....prolly be just about right.
Old Dec 15, 2010 | 12:47 PM
  #137
Departed's Avatar
I think I might be going with the FIC 1680's but I am being told by RRE that RC's being spliced in etc would be their recommendation still. Anyone see a problem with doing that? I trust RRE, just like to see if anyone has any thoughts to add.
I will definitely be going for the jay racing modified walbro 255 (342 version) pump and blaqops kit as it will outflow the Bosch 044 and the DW300 IIRC. Don't quote me on that but it's food for thought as I believe it's cheaper as well.
Pump can be found here if you want to check it out (I confirmed that version 342 of the walbro pumps is what comes with the blaqops kit): http://www.jayracing.com/index.php?m...oducts_id=2619
Old Dec 15, 2010 | 02:24 PM
  #138
mrfred's Avatar
I'm on a single three year old Walbro right now with no sign of leaning out at peak fuel flow (at 25 psi of boost). That's without the pressure relief valve mod. My guess is that I'll be able to make 500 whp on the single Walbro. If you're needing more than 500 whp, I think the the DW300 paired with FIC1680s is good for a solid 650 whp on E85. Seems like the perfect combo for the 500-650 whp E85 builds.
Old Dec 17, 2010 | 09:02 PM
  #139
pikkagtr's Avatar
Just had the DW1300s replaced with the FIC1680s
Boy what a difference!
Idle is just like stock and cruise/ part throttle if VERY crisp!
So far I'm a very happy camper!
Old Dec 18, 2010 | 12:23 PM
  #140
vr4_rider's Avatar
Hey, guys.
I have high z injectors and AEM EMS 2 and I don't need the injector driver.
How do I jump the wires so it completes the circuit?
Here's the ECM pinout:
1 Number 1 Injector Ground Control
2 Number 3 Injector Ground Control
3 Number 5 Injector Ground Control
14 Number 2 Injector Ground Control
15 Number 4 Injector Ground Control
16 Number 6 Injector Ground Control
Here's the diagram:
Thanks!
Old Dec 18, 2010 | 03:27 PM
  #141
Golden's Avatar
Um 6 cylinders? Are you in the right place?
Old Dec 18, 2010 | 03:50 PM
  #142
vr4_rider's Avatar
LOL, I figured it out
Old Dec 20, 2010 | 04:47 PM
  #143
VGergo's Avatar
Originally Posted by Golden
I got mine today. It seems they are now cutting the long shaft off. They look like this:
How the FIC 1100 for Evo X looks like ? as in the picture posted by Golden or like this ?
Why most aftermakert injectors cut down the long shaft ?
Old Dec 20, 2010 | 08:58 PM
  #144
E6-X's Avatar
spray pattern ???
Old Dec 21, 2010 | 08:05 AM
  #145
fostytou's Avatar
EvoM Community Team
Theres an explanation on here somewhere... I think Bosch changed the body style, and there were possibly concerns about valve contact on certain engines. More specifically though, the ones that you just posted a picture of have the anodized top... I'm pretty sure thats only on the 2000cc model.
Old Dec 21, 2010 | 08:24 AM
  #146
mrfred's Avatar
Actually, its the same exact injector in both pictures above. The difference is the spacers that are used. The picture with the long snout has no lower spacer but has an upper spacer while the injector that apparently has no snout uses a lower spacer but no upper spacer.
Old Jan 26, 2011 | 09:22 PM
  #147
silentsniper605's Avatar
maxed out my fic 1100cc , 527whp on e85
Old Jan 26, 2011 | 10:26 PM
  #148
Golden's Avatar
Nice. DynoJet I presume. Speed Technique's Dyno Jet?
Old Jan 26, 2011 | 10:42 PM
  #149
mrfred's Avatar
Sounds about right for DJ numbers. What AFR?
Old Jan 27, 2011 | 07:14 AM
  #150
1800bigk's Avatar
I am loving my FIC 1100s. It's been getting down to single digit temps around here some mornings, they still start right up and idle like stock, you can't even tell a difference.
