EvoScan Help
Old May 1, 2010 | 06:17 PM
mirXa's Avatar
EvoScan Help
I want to log the car for now and need some help on how to go about setting it up for evoscan. I have the op2.0 cable but looking for a step by step guide on how to go about connecting the car etc but hvnt found anything on the forums for now. I am new to this and would rather ask you guys then screw something up. Also do i need to enable mode 23 on the ecu in-order to log or can it be done without it? Anything else i should be aware of? Thanks!!
Old May 2, 2010 | 03:14 AM
evilevox's Avatar
evoscan
Hey
It's all pretty straight forward to start with. You just need to plug the openport adapter into the obd connector above your accelerator pedal. Plug the usb cable into your laptop. Then select the Openport 2 radius button, and then select your ECU from the 'select ECU' dropdown. Then just select the items you want to log then hit the 'start logging' button. and you're good to go.
cheers
Old May 2, 2010 | 05:40 AM
E6-X's Avatar
1. Enable mode23
2. the OBD port is just below your fusebox or above brake pedal. plug it in
3. plug USB to laptop
4. select/tick OP 2.0 / CAN 2006+/Evox when you see main screen on top left
5. Select ECU ie Mode23 2008 Evox USA
6. tick items you want to log, the lesser, the faster the logging
7. hit START Datalogger .... "Link engaged" LOL
Have fun, make sure eyes are on the road !
Old May 2, 2010 | 10:56 AM
mirXa's Avatar
Hey guys thanx for the input....one more thing what is mode 23 to being with? Does enabling it unlock any parameters for the ECU? Have been trying to find a basic thread which describes what it is however there are countless ones with instructions on how to go about enabling it. Also i have a European Spec Evo X so will i still need to configure mode 23 or can i just log without it? Sorry for all the questions guys i new to this and trying to get as much info as i can.
Cheers!
Old May 2, 2010 | 11:09 AM
E6-X's Avatar
here you go my friend . . . start reading ! LOL
https://www.evolutionm.net/forums/ev...lustrated.html
and what is your romid ? EcuFlash should be able to tell you or if it's too complicated, after reading and done with the process above in EvoScan select Mode23 2008 Evox JDM for EU specs.
Old May 2, 2010 | 12:17 PM
mirXa's Avatar
Thank you! I have gone though this post already its pretty informative however i still want to know in basic terms what is the mode 23 all about? Also i don't know for now what the romid is. Can i just connect it to Ecuflash and find out those details? Btw are you based in Oman?
Old May 2, 2010 | 03:30 PM
E6-X's Avatar
you can give it a shot but if you are new to the tuning world i would advise you not to touch the settings or numbers except for enabling mode23. yep i'm based in oman. u ?
Old May 5, 2010 | 11:55 AM
mirXa's Avatar
No i don't intend to make any changes just want to log the car ill most probably be getting a remote flash or fly in my tuner for the tune...i am in Dubai... don't trust any tuner's here
Old May 5, 2010 | 12:06 PM
E6-X's Avatar
u can drive here or i can fly down. pm me
Old May 5, 2010 | 12:47 PM
CatalystGod's Avatar
I may be wrong but here goes nothing:
Mode 23 is basically editing the ROM on your car by changing 3 hex values that allows EvoScan to directly log current values in realtime when logging. For example, think of it as RAM addresses, if you are proficient in computers. You are basically giving access to RAM address locations where current Boost, RPM etc are kept in real time.
I may be totally off in my knowledge of the matter, but this is what I think I know.
Old May 6, 2010 | 09:46 AM
mirXa's Avatar
Thanks really appreciate your input..... wanted to know for my own knowledge in lay man terms what it is or does as most the stuff on the forums is mostly talking about how to go about activating it rather then explaining what is actually is...
Old May 6, 2010 | 10:26 AM
You're welcome, that's what the forums are here for. Happy logging & tuning
Old May 6, 2010 | 12:08 PM
E6-X's Avatar
in layman terms, you make them speak the same lingo so life is easier for both parties
darkmitsu
Lancer Engine Management / Tuning Forums
141
Dec 31, 2022 05:41 AM
Edik_898_
Nov 28, 2016 02:02 PM
roni4g63
Nov 14, 2015 11:45 AM
evo4mad
May 5, 2015 06:22 PM
worksevo89
Nov 14, 2008 11:38 AM
