EvoScan Problem - VIDEO
Old May 10, 2010 | 10:18 AM
Octane Blue's Avatar
Just a noob looking for help
I have the following -
2010 GSR X
Rom ID: 55570005
Mode 23 Enabled
Lean Spool Off
Evoscan 2.7 Beta 5
I have attached a video via YouTube with the problem I am having. It seems that some parameters for my car are not working..
The drop down menu ("Select ECU") has a few options. The only option I can get to read my knock correctly is the "EVO X" option. Only problem, I can't seem to get the TPS to function properly, nor read my MAP in psi correctly.
When choosing "Mode 23 USA EVOX" a lot of the parameter readings are screwed up. 32 counts of knock at idle, 105+fluctuation on accel pedal pos.. etc.
Guess a couple of my addresses are wrong? Any help is appreciated. Thanks in advance.
http://www.youtube.com/watch?v=g7UhrUzMdVc
Old May 10, 2010 | 11:17 AM
tonyboy's Avatar
use the "Mode 23 2010 USA EVOXRA" for the 55570005..that's what i use..all is accurate except for the TPS
100% wot = 87% in evoscan (at least from what i know because in ztx logger it's 100%)
also there are still a lot of table definitions missing for our rom id..
Old May 10, 2010 | 01:13 PM
Thanks. I posted this on the other evo x forum in my sig. I think ill get things working by tonight.
Old May 11, 2010 | 02:59 AM
NZEvox's Avatar
you need to check the mode 23 on your rom.It does that on the knock count when it is not enabled correctly. here is the link
https://www.evolutionm.net/forums/ev...lustrated.html
Maybe it is not enabled correctly
Old May 11, 2010 | 06:17 AM
tephra's Avatar
nah he just needs to use the right evox type in evoscan
Old May 11, 2010 | 11:57 PM
Everything worked out fine. It was just a couple addresses that were incorrect.
Old May 12, 2010 | 11:37 AM
PR_Mivec's Avatar
i still use the beta logger Tephra wrote o.O
evo4mad
May 5, 2015 06:22 PM
Fede
Oct 26, 2014 10:41 AM
RS200Z
Jan 12, 2013 06:42 PM
BlackPit
Jul 30, 2012 06:47 AM
therocket
Jun 2, 2010 10:09 AM
