Some GTR Goodness in the EvoScan GPS
Old May 12, 2010 | 07:41 PM
CatalystGod's Avatar
Mods, can we start a sticky for all layouts and corresponding settings?
Was feeling bored and decided to do the GTR layout for the GPS on RogEvo25's request. Sorry for the **** poor quality. I want to add the remaining gauges for functionality and then release the settings. currently last gauge on first line and last 2 gauges on second line are not working/assigned.
http://www.youtube.com/watch?v=jKF5_k9z_lo
My mad MS Paint skillzzzzzz MS PAINT FTW !!!!!
Here are the attachments:
The Alarms.txt and EvoScan.txt need to be renamed to ".xml" files. The bus_horn.txt file needs to be renamed to a .wav file for the alarm to work.
File Type: txt
File Type: txt
File Type: txt
File Type: txt
Old May 12, 2010 | 09:19 PM
tephra's Avatar
nice...
Old May 12, 2010 | 09:20 PM
DSMorBUST's Avatar
pretty cool..
Old May 13, 2010 | 04:12 AM
evoscan's Avatar
Silver Sponsor
Interesting timing... check out the one I'm working on... spent 1 evening on it so far.. its come along nicely..
Old May 13, 2010 | 04:45 AM
vboy425's Avatar
very nice indeed. link it for download would be even nicer lol.
Old May 13, 2010 | 04:52 AM
E6-X's Avatar
yay +1 for DL nice gauge
boy36's Avatar
Great keep us updated.Any download link?
Old May 13, 2010 | 05:25 AM
That's what I started with, I eventually ended up with what I posted.
Old May 13, 2010 | 05:27 AM
I can put it up for download as is, takes about 2 minutes, but I want to assign the remaining gauges to proper log items too and then set it up for other to download.
I know I haven't been doing anything for our SST friends, but honestly, it won't be too different.
Old May 13, 2010 | 05:37 AM
I'm looking for more inputs on what we can log with the remaining gauges.
The last gauge in the first line is reserved for Oil Pressure, I do not know if we can log that from the ECU using EvoScan.
The last 2 gauges in the second line are completely up for grabs though.
I can also include numeric fields like the Knock in the posted picture. I'm thinking
1) Timing advance
2) LTFT
3) LOAD
what else???
Old May 14, 2010 | 12:14 AM
evoscan's Avatar
Silver Sponsor
I don't think EvoX have has any oil pressure sensor installed in the engine bay?
Old May 14, 2010 | 05:54 AM
E6-X's Avatar
top 3 gauge --- AFR, Boost, Knock
bottom 3 --- SST temp, Load, Timing adv
i'll call it a day ! yay .... thx in advance
Old May 14, 2010 | 06:42 AM
yeah, I don't know if there is a sensor for oil pressure in the X, just kept the gauge since most people want it and because I know you will figure out a way to read this too
Old May 14, 2010 | 06:48 AM
Do you really want to see "Load" in realtime? I thought most liked it for logging and tuning purposes.
I have decided to use Gauge 2 in line 2 for speed to failitate for those that run tires with different circumferences compared to the stock setup. Currently, you'll need to make a change to the EVAL portion of the "Speed" element in the data.xml file. I tested this last night with my 265 35 18 RE11's and it works well. The speed shown in the gauge is now the same as the one shown in my Garmin GPS. The stock speedo thinks I am going faster.
only one more gauge to go (line 2 gauge 3). The SST guys might want to use this for the SST temp, I agree, but what about the GSR owners? Timing adv and knock have already been implemented as numeric gauges. So we need something else.
Old May 14, 2010 | 07:55 AM
migs647's Avatar
/subscribed
+1 for SST temp .
So in order to get this to show on my AUX of my Kenwood DNX-8120, I'd just need a small computer built into the car and plugged into the Kenwood right? (The computer would be running EvoScan)?
