2009 EVOX definition file
Old Jun 7, 2010 | 08:59 AM
Golden's Avatar
I don't suppose you have 52370024 also? I was hoping 52370023 worked for 52370024, but it looks like it is different.
Old Jun 7, 2010 | 03:56 PM
stackhouse's Avatar
Dont have one for the 0024. If it doesnt already exist, I could make one, I suppose. I dont remember when I came up with the 0023, I cant remember actually doing that one. But it seems to work, so...
Old Sep 14, 2010 | 11:30 AM
Mellon Racing's Avatar
ran into another one I don't have a definition for, does anyone have info on this?
53050012 it's a Dubai customer with a 2009 EVO X MR SST Auto Transmission
Old Sep 15, 2010 | 07:24 AM
Golden's Avatar
Is it the same as 53050009?
53050009:
Code:
<rom>
	<romid>
		<xmlid>53050009</xmlid>
		<internalidaddress>5002a</internalidaddress>
		<internalidhex>53050009</internalidhex>
		<make>Mitsubishi</make>
		<market>EDM</market>
		<model>Lancer</model>
		<submodel>Evolution X MR</submodel>
		<transmission>Auto</transmission>
		<year>2008</year>
		<flashmethod>mitsucan</flashmethod>
		<memmodel>M32186F8</memmodel>
		<checksummodule>mitsucan</checksummodule>
	</romid>
	<include>evo10base</include>
	<table name="High Octane Timing Map" address="5590f">
		<table name="Load" address="60fb2"/>
		<table name="RPM" address="615f2"/>
	</table>
	<table name="Low Octane Timing Map" address="55b11">
		<table name="Y" address="615f2"/>
	</table>
	<table name="MIVEC Intake #1" address="5db59">
		<table name="Load" address="615c0"/>
		<table name="RPM" address="615f0"/>
	</table>
	<table name="MIVEC Intake #2" address="5dd59">
	</table>
	<table name="MIVEC Exhaust #1" address="5e159">
	</table>
	<table name="MIVEC Exhaust #2" address="5df59">
	</table>
	<table name="Ignition Warmup Retard" address="5b8c5">
		<table name="RPM" address="60f7e"/>
	</table>
	<table name="EGR Timing Advance" address="572b9">
		<table name="Load" address="6155c"/>
		<table name="RPM" address="61542"/>
	</table>
	<table name="High Octane Fuel Map" address="55027">
		<table name="Load" address="60fb4"/>
		<table name="RPM" address="60eec"/>
	</table>
	<table name="Low Octane Fuel Map" address="552d7">
	</table>
	<table name="Fuel Alt #1" address="5517f">
	</table>
	<table name="Fuel Alt #2" address="5542f">
		<table name="Y" address="60eec"/>
	</table>
	<table name="Max Rich AFR Clip vs Coolant Temp" address="5a1b0">
		<table name="Coolant Temperature" address="5d2cc"/>
	</table>
	<table name="Fuel Injector Scaling" address="536cc"/>
	<table name="Injector Battery Voltage Latency Compensation" address="556d0">
		<table name="Battery Voltage" address="60e60"/>
	</table>
	<table name="Injector Base Latency" address="53000"/>
	<table name="Evap Map #1" address="55d13">
	</table>
	<table name="Evap Map #2" address="55f15">
	</table>
	<table name="Open Loop Load Low Octane #1" address="555c2">
		<table name="RPM" address="60db2"/>
	</table>
	<table name="Open Loop Load High Octane #1" address="574cc">
	</table>
	<table name="Open Loop Load Low Octane #2" address="555c2">
	</table>
	<table name="Open Loop Load High Octane #2" address="574b4">
	</table>
	<table name="Cylinder Fuel Trim #1" address="57db1">
		<table name="RPM" address="61a0e"/>
	</table>
	<table name="Cylinder Fuel Trim #2" address="57f9b">
	</table>
	<table name="Cylinder Fuel Trim #3" address="58185">
	</table>
	<table name="Cylinder Fuel Trim #4" address="5836f">
	</table>
	<table name="Boost Control Load Offset" address="53484"/>
	<table name="Boost Target Engine Load #1A (High Gear Range)" address="58e45">
		<table name="Throttle" address="6264e"/>
		<table name="RPM" address="625cc"/>
	</table>
	<table name="Boost Target Engine Load #1B (High Gear Range)" address="58eef">
	</table>
	<table name="Boost Target Engine Load #2 (Low Gear Range)" address="573f5">
	</table>
	<table name="Reactive Solenoid Base WGDC Map #1A (High Gear Range)" address="58cf1">
	</table>
	<table name="Reactive Solenoid Base WGDC Map #1B (High Gear Range)" address="58d9b">
	</table>
	<table name="Reactive Solenoid Base WGDC Map #2 (Low Gear Range)" address="5734b">
	</table>
	<table name="Reactive Solenoid WGDC Correction Interval (High Gear Range)" address="5346a" level="4"/>
	<table name="Reactive Solenoid WGDC Correction Interval (Low Gear Range)" address="5467a" level="4"/>
	<table name="Reactive Solenoid Turbo Boost Error Correction" address="58cd8">
		<table name="Load Error" address="625f6"/>
	</table>
	<table name="Reactive Solenoid Max Total Upward WGDC Correction vs TPS" address="58cca" level="4">
		<table name="TPS" address="62636"/>
	</table>
	<table name="Reactive Solenoid Max Total Downward WGDC Correction" address="5346c"/>
	<table name="Passive Solenoid Base WGDC Map #1A (High Gear Range)" address="5a1e6">
	</table>
	<table name="Passive Solenoid Base WGDC Map #1B (High Gear Range)" address="5a1fc">
	</table>
	<table name="Passive Solenoid Base WGDC Map #2 (Low Gear Range)" address="5a212">
	</table>
	<table name="Boost Control RPM Per MPH Xover (Gear Based)" address="5466a" level="4"/>
	<table name="Boost Limit" address="555b4">
		<table name="RPM" address="61596"/>
	</table>
	<table name="Boost Cut Delay Timer" address="53068"/>
	<table name="Throttle Map #1" address="50b64">
		<table name="Unkown" address="6140c"/>
		<table name="RPM" address="61338"/>
	</table>
	<table name="Throttle Map #2" address="5118e">
		<table name="Unknown" address="6140c"/>
	</table>
	<table name="Throttle Map #3" address="517b8">
		<table name="RPM" address="61326"/>
	</table>
	<table name="Throttle Map #4" address="51de2">
	</table>
	<table name="Throttle Map #5" address="5240c">
	</table>
	<table name="Throttle Conditional Switch" address="5495a"/>
	<table name="Rev Limiter" address="5305e">
	</table>
	<table name="Stationary Rev Limiter" address="53442">
	</table>
	<table name="Speed Limiter" address="53062">
	</table>
	<table name="Airflow Check #1" address="5e985">
		<table name="TPS-Related" address="624cc"/>
		<table name="RPM" address="624a4"/>
	</table>
	<table name="Airflow Check #2" address="5ea7b">
	</table>
	<table name="Airflow Check #3" address="5eb71">
	</table>
	<table name="Airflow Check #4" address="5ec7b">
		<table name="TPS-Related" address="62514"/>
		<table name="RPM" address="624a6"/>
	</table>
	<table name="Torque Limiter #1" address="63847">
	</table>
	<table name="Torque Limiter #2" address="6393d">
	</table>
	<table name="Torque Limiter #3" address="63a33">
	</table>
	<table name="Torque Limiter #4" address="63b29">
	</table>
	<table name="Flow Check table" address="60ac5">
		<table name="Load" address="62ab0"/>
		<table name="RPM" address="62a98"/>
	</table>
	<table name="Knock Filter #1" address="56703">
		<table name="Load" address="611ec"/>
		<table name="RPM" address="611b4"/>
	</table>
	<table name="Knock Filter #2" address="5692b">
		<table name="X" address="611ec"/>
		<table name="Y" address="611b4"/>
	</table>
	<table name="Knock Filter #3" address="56873">
	</table>
	<table name="Knock Filter #4" address="567bb">
	</table>
	<table name="Knock Filter #5" address="5664b">
	</table>
	<table name="Idle RPM #1 vs Coolant Temp" address="5f344">
		<table name="Coolant Temperature" address="61016"/>
	</table>
	<table name="Idle RPM #2 vs Coolant Temp" address="5f338">
	</table>
	<table name="Idle RPM #3 vs Coolant Temp" address="561fe">
		<table name="Coolant Temperature" address="61252"/>
	</table>
	<table name="Idle RPM #4 vs Coolant Temp" address="5a894">
	</table>
	<table name="Idle RPM #5 vs Coolant Temp" address="561fe">
	</table>
	<table name="Idle RPM #6 vs Coolant Temp" address="5a8b6">
	</table>
	<table name="Idle RPM #7 vs Coolant Temp" address="5a8b6">
	</table>
	<table name="Idle RPM #8 vs Coolant Temp" address="59e04">
	</table>
	<table name="Idle RPM #9 vs Coolant Temp" address="59e04">
	</table>
	<table name="Idle Adder #1 vs Coolant Temp" address="609c8">
		<table name="Coolant Temperature" address="61042"/>
	</table>
	<table name="Idle Adder #2 vs Coolant Temp" address="609d6">
	</table>
	<table name="Target Idle #1" address="533c6"/>
	<table name="Target Idle #2" address="53c78"/>
	<table name="Target Idle #3" address="53c7a"/>
	<table name="Target Idle #4" address="532de"/>
	<table name="Target Idle #5" address="53d74"/>
	<table name="Target Idle #6" address="532da"/>
	<table name="Target Idle #7" address="532e0"/>
	<table name="Target Idle #8" address="53d76"/>
	<table name="Target Idle #9" address="532dc"/>
	<table name="Target Idle #10" address="54016"/>
	<table name="Target Idle #11" address="54016"/>
	<table name="Target Idle #12" address="54894"/>
	<table name="Target Idle #13" address="54894"/>
	<table name="Target Idle #14" address="54ac4"/>
	<table name="ECU ID" address="5002a" type="1D" scaling="ECU ID"/>
	<table name="MUT Table" address="3e668">
	<table name="MUT Table" address="3e39c">
		<table name="X"/>
		<table name="Y"/>
	</table>
</rom>
Old Sep 15, 2010 | 01:13 PM
Golden, I was thinking along the same lines and tried 53050006 but no luck. I didn't have the one you posted but it didn't work either.
Old Sep 15, 2010 | 01:17 PM
the file is too big to attach but pm me your email if you want a copy to play with. I've probably overlooked something obvious again from staring at cells all day.
devojet
Lancer Aftermarket Forced Induction Tech
28
Jul 22, 2025 12:53 AM
Carvs
Sep 7, 2016 02:21 PM
grim~
Mar 27, 2010 05:47 PM
scottmanevo
Nov 7, 2009 12:57 PM
iggy2009
Jul 7, 2009 08:30 AM
