What would be the recommended cut off amount of boost for a stock turbo?
I have an Evo VIII with the 10.5 hotside and mine peaks at 25 PSI on 93 oct. without any problems whatsoever. I've been told that the IX turbo can handle up to 28 or 29 reliably, but I'm no expert that's just what I've been told.
evo9 turbo is a little more capable than the X
yeah abt 20'ish or more psi @ 7K RPM's and above will be hot air coming through, depending where on earth you are located (weather conditions, elevation,etc) and thats why i suggested taper to 18 or below 20 psi (max) would be a safe margin and lesser knock counts and probably run 1-2 deg of timing more instead of hot air.
of course fuel type, engine health, setup (WI/WMI) and if the stock injector still can supply enough fuel at that boost level at high rpms counts too. Happy TOOONING
i ain't pro but just my 2 cents
Either that or the 4g63 had more restrictions to the intake (heads / valves) and maintained a higher pressure due to more resistance. It's really like comparing apples and oranges. I believe the compressors are identical with the 9 having a 10.5 hotside and the X having 12.5 hotside.
LOL, who knows. Either way it's a decent size for some good power and plenty of fun!
Read the topic title carefully it does say "cut off amount of boost" i'm pretty sure we cut it off at the redline area don't we ?
guess you're right teph but 1 thing for sure the flow capability of X turbo is similar or "just" a little more than a e6 turbo.
"LOL, who knows. Either way it's a decent size for some good power and plenty of fun! "
could not agree more with this statement ! yehaaaa
happy boostin' guys
FWIW I'm running 26psi now with a upgraded FMIC and 3 port and it runs great on 93. My 2008 was tuned to 28-29psi on 93 and ran hard as well, that car also had a upgraded FMIC. I'd say on stock FMIC 25-26 on 93 is probably about the peak efficiency with a taper to about 18-19psi
FL_SilverEvo8
Apr 30, 2009 09:05 PM
