Hot start fix for the EVOX's.
I have a similar problem, but I'm not sure if it's the same. Here goes
At the track, my coolant temps are usually ~80*C after my cool down lap when I get to the pits. Once I go to start the car up again, it'll fire right up first try every time, BUT my AFR at idle will be high 12's to high 13's. It's usually around stoich.
This causes the car to stutter while idling and makes the idle sporadic, hopping between 500 and 1500rpm. Sometimes throws a Too Rich CEL. This has happened at least three times in the past few months, and typically clears out after a couple hours. It's always happened in the last couple of sessions of the day when the ambient temps are highest. However, when not ideling, the car seems to run fine. When this happens, I usually let it cool down as long as possible hoping it goes away, but I have no idea why it's happening or how to combat it.
At first I thought that running WOT on the long straights might have gunked up my O2 sensors with unburnt fuel, and it might just take a while to clear out. Someone mentioned adjusting the cranking enrichment tables, which I thought was just for problems cranking, and mostly in the cold. This thread indicates otherwise.
I'm on the stock injectors & stock turbo with basic breathing boltons running about 25psi. Would adjusting high temp cranking enrichment help in my case, does it only apply when the starter is active? Any other ideas?
David or anyone else have the Cranking Enrichment IPW adder values for an Evo 9 with the ID1000 injectors? I've had the warm start problem for a long time...it's really getting annoying down here in south FL. Thanks
evo 9 with same issues on id1000ccs, not matter how the IPW crank table is massaged... leaking ID1000ccs or slow response from them are giving an AEM series 1 impression on the stock ECU
Injector clinic might be the way to go..
However... i believe for mine this is from a "Cold" start.. occationaly i will try to start the car.. cranks 3-4 times i stop.. wait a second then try again.. wait a second.. then i tap the gas a couple times and try again .. usually after i tap the gas it will start.. i really dont know if taping the gas even does anything.. since it's not a carburated engine.. either way that 3rd or sometimes 4th time trying to start.. ends up starting the engine.. i haven't been stranded yet.. but dam my old 2003 Hyundai would crank once or twice and would start even if it was -50C.. Not even kidding.. it was -52C few winters back with the wind chill factor in. started up no prob not even pluged in. the trans felt like a stick in cold molasses but still started.
I contacted injector dynamics about my warm start problems and they asked me to send them in for free testing... after testing they found my set did leak very slightly and they offered to replace them for free. I should have them back in the car in a week or so and will post my findings.
mrfred
Feb 26, 2022 06:16 PM
Mad_SB
10
May 13, 2011 11:46 AM
