52360018 clean xml needed
Old Aug 18, 2010 | 11:33 AM
Dragon-V's Avatar
Hi,
Does anyone have a clean xml they can post up or mail please as mine is all over the place.
Internal id is SM5236
Email is leejbell@hotmail.com
Many thanks
Lee
Old Aug 18, 2010 | 07:16 PM
Golden's Avatar
This is what I have. I'm not sure how exact or correct it is.
Code:
<rom>
    <romid>
        <xmlid>52360018</xmlid>
        <internalidaddress>5002A</internalidaddress>
        <internalidhex>52360018</internalidhex>
        <make>Mitsubishi</make>
        <market>JDM</market>
        <model>Lancer</model>
        <submodel>Evolution X</submodel>
        <transmission>5MT</transmission>
        <year>2008</year>
        <flashmethod>mitsucan</flashmethod>
        <checksummodule>mitsucan</checksummodule>
        <memmodel>M32186F8</memmodel>
    </romid>
    <include>evo10base</include>
<!--    <include>52680015_mods</include>   -->
<!--  **Timing**  -->
    <table name="High Octane Timing Map" address="5590f">
        <table name="Load" address="60f7a"/>
        <table name="RPM" address="616f8"/>
    </table>
    <table name="Low Octane Timing Map" address="55b11">
        <table name="Y" address="616f8"/>
    </table>
    <table name="MIVEC Intake #1" address="5dd21">
        <table name="Load" address="61588"/>
        <table name="RPM" address="615b8"/>
    </table>
    <table name="MIVEC Intake #2" address="5db21">
    </table>
    <table name="MIVEC Exhaust #1" address="5e121">
    </table>
    <table name="MIVEC Exhaust #2" address="5df21">
    </table>
    <table name="Ignition Warmup Retard" address="5b8a9">
        <table name="RPM" address="60f46"/>
    </table>
    <table name="EGR Timing Advance" address="572b9">
        <table name="Load" address="61524"/>
        <table name="RPM" address="6150a"/>
    </table>
<!--  **Fuel Control**  -->
    <table name="High Octane Fuel Map" address="55027">
        <table name="Load" address="60f00"/>
        <table name="RPM" address="60eda"/>
    </table>
    <table name="Low Octane Fuel Map" address="552d7">
        <table name="Load" address="63cca"/>
        <table name="RPM" address="63d22"/>
    </table>
    <table name="___Max Rich AFR Clip vs Coolant Temp" address="5a190">
        <table name="Coolant Temperature" address="5d290"/>
    </table>
    <table name="Fuel Injector Scaling" address="536cc"/>
    <table name="Injector Battery Voltage Latency Compensation" address="556d0">
        <table name="Battery Voltage" address="60e6a"/>
    </table>
    <table name="Injector Base Latency" address="53000"/>
    <table name="Evap Map #1" address="55d13">
    </table>
    <table name="Evap Map #2" address="55f15">
    </table>
    <table name="___Open Loop Load Low Octane #1" address="555da">
        <table name="RPM" address="60d76"/>
    </table>
    <table name="Open Loop Load High Octane #1" address="574cc">
        <table name="RPM" address="60d7a"/>
    </table>
    <table name="___Open Loop Load Low Octane #2" address="555c2">
    </table>
    <table name="Open Loop Load High Octane #2" address="574b4">
    </table>
    <table name="Cylinder Fuel Trim #1" address="57db1">
        <table name="RPM" address="619d6"/>
    </table>
    <table name="Cylinder Fuel Trim #2" address="57f9b">
    </table>
    <table name="Cylinder Fuel Trim #3" address="58185">
    </table>
    <table name="Cylinder Fuel Trim #4" address="5836f">
    </table>
<!--  **Turbo Control**  -->
    <table name="Boost Control Load Offset" address="53484"/>
    <table name="Boost Target Engine Load #1A (High Gear Range)" address="58e45">
        <table name="Throttle" address="62616"/>
        <table name="RPM" address="62594"/>
    </table>
    <table name="Boost Target Engine Load #1B (High Gear Range)" address="58eef">
    </table>
    <table name="Boost Target Engine Load #2 (Low Gear Range)" address="573f5">
    </table>
    <table name="Reactive Solenoid Base WGDC Map #1A (High Gear Range)" address="58cf1">
    </table>
    <table name="Reactive Solenoid Base WGDC Map #1B (High Gear Range)" address="58d9b">
    </table>
    <table name="Reactive Solenoid Base WGDC Map #2 (Low Gear Range)" address="5734b">
    </table>
    <table name="___Reactive Solenoid WGDC Correction Interval (High Gear Range)" address="5346a"/>
    <table name="___Reactive Solenoid WGDC Correction Interval (Low Gear Range)" address="5467a"/>
    <table name="Reactive Solenoid Turbo Boost Error Correction" address="58cd8">
        <table name="Load Error" address="625bc"/>
    </table>
    <table name="___Reactive Solenoid Max Total Upward WGDC Correction vs TPS" address="58cc6">
      <table name="TPS" address="625f8"/>
    </table>
    <table name="___Reactive Solenoid Max Total Downward WGDC Correction" address="5346c"/>
    <table name="Passive Solenoid Base WGDC Map #1A (High Gear Range)" address="5a1ca">
    </table>
    <table name="Passive Solenoid Base WGDC Map #1B (High Gear Range)" address="5a1e0">
    </table>
    <table name="Passive Solenoid Base WGDC Map #2 (Low Gear Range)" address="5a1f6">
    </table>
    <table name="___Boost Control RPM Per MPH Xover (Gear Based)" address="5466a"/>
    <table name="Boost Limit" address="555b4">
        <table name="RPM" address="6155e"/>
    </table>
    <table name="Boost Cut Delay Timer" address="53068"/>
<!--  **Throttle Control**  -->
    <table name="Throttle Map #1" address="50b64">
        <table name="Unknown" address="613d4"/>
        <table name="RPM" address="61326"/>
    </table>
    <table name="Throttle Map #2" address="5118e">
    </table>
    <table name="Throttle Map #3" address="517b8">
    </table>
    <table name="Throttle Map #4" address="51de2">
    </table>
    <table name="Throttle Map #5" address="5240c">
    </table>
    <table name="Throttle Conditional Switch" address="5494e"/>
<!--  **Limits**  -->
    <table name="Rev Limiter" address="5305e"/>
    <table name="Stationary Rev Limiter" address="53442"/>
    <table name="Speed Limiter" address="53062"/>
    <table name="Airflow Check #1" address="5e94d">
        <table name="Throttle" address="62494"/>
        <table name="RPM" address="6246c"/>
    </table>
    <table name="Airflow Check #2" address="5ea43">
    </table>
    <table name="Airflow Check #3" address="5eb39">
    </table>
    <table name="Airflow Check #4" address="5ec43">
        <table name="TPS-Related" address="624dc"/>
        <table name="RPM" address="624b6"/>
    </table>
    <table name="Torque Limiter #1" address="6380f">
        <table name="TPS-Related" address=" 62494"/>
    </table>
    <table name="Torque Limiter #2" address="63905">
        <table name="TPS-Related" address="62494"/>
    </table>
    <table name="Torque Limiter #3" address="639fb">
    </table>
    <table name="Torque Limiter #4" address="63af1">
    </table>
    <table name="Flow Check table" address="60a8d">
        <table name="TPS-Related" address="62a78"/>
        <table name="RPM" address="62a60"/>
    </table>
<!--  **Knock Detection**  -->
    <table name="Knock Filter #1" address="56703">
        <table name="X" address="611b4"/>
        <table name="Y" address="61198"/>
    </table>
    <table name="Knock Filter #2" address="5692b">
    </table>
    <table name="Knock Filter #3" address="56873">
    </table>
    <table name="Knock Filter #4" address="567bb">
    </table>
    <table name="Knock Filter #5" address="5664b">
    </table>
<!--  **IDLE**  -->
    <table name="Idle RPM #1 vs Coolant Temp" address="5f308">
      <table name="Coolant Temperature" address="60ff0"/>
    </table>
    <table name="Idle RPM #2 vs Coolant Temp" address="5f2fc">
    </table>
    <table name="Idle RPM #3 vs Coolant Temp" address="561ee">
      <table name="Coolant Temperature" address="6122c"/>
    </table>
    <table name="Idle RPM #4 vs Coolant Temp" address="5a874">
    </table>
    <table name="Idle RPM #5 vs Coolant Temp" address="561fa">
    </table>
    <table name="Idle RPM #6 vs Coolant Temp" address="5a8a2">
    </table>
    <table name="Idle RPM #7 vs Coolant Temp" address="5a896">
    </table>
    <table name="Idle RPM #8 vs Coolant Temp" address="59df0">
    </table>
    <table name="Idle RPM #9 vs Coolant Temp" address="59de4">
    </table>
    <table name="Idle Adder #1 vs Coolant Temp" address="6098c">
      <table name="Coolant Temperature" address="61006"/>
    </table>
    <table name="Idle Adder #2 vs Coolant Temp" address="6099A">
    </table>
    <table name="Target Idle #1" address="533c6"/>
    <table name="Target Idle #2" address="53c74"/>
    <table name="Target Idle #3" address="53c76"/>
    <table name="Target Idle #4" address="532de"/>
    <table name="Target Idle #5" address="53d70"/>
    <table name="Target Idle #6" address="532da"/>
    <table name="Target Idle #7" address="532e0"/>
    <table name="Target Idle #8" address="53d72"/>
    <table name="Target Idle #9" address="532dc"/>
    <table name="Target Idle #10" address="54012"/>
    <table name="Target Idle #11" address="54016"/>
    <table name="Target Idle #12" address="54886"/>
    <table name="Target Idle #13" address="54888"/>
    <table name="Target Idle #14" address="54ab6"/>
<!--  **Misc**  -->
    <table name="ECU ID" address="5002A" type="1D" scaling="ECU ID"/>
 <!--  *** MUT ***  -->
   <table name="MUT Table" address="3ea64">
     <table name="X"/>
     <table name="Y"/>
   </table>
</rom>
Old Aug 19, 2010 | 02:28 AM
Dragon-V's Avatar
Code:
<rom>
    <romid>
        <year>2008</year>
    </romid>
<!--  **Timing**  -->
    </table>
    </table>
    </table>
    </table>
    </table>
    </table>
    </table>
    </table>
    </table>
    </table>
    </table>
    </table>
    </table>
    </table>
    </table>
    </table>
    </table>
    </table>
    </table>
    </table>
    </table>
    </table>
    </table>
    </table>
    </table>
    </table>
    </table>
    </table>
    </table>
    </table>
    </table>
    </table>
    </table>
    </table>
    </table>
    </table>
    </table>
    </table>
    </table>
<!--  **Limits**  -->
    </table>
    </table>
    </table>
    </table>
    </table>
    </table>
    </table>
    </table>
    </table>
    </table>
    </table>
    </table>
    </table>
    </table>
<!--  **IDLE**  -->
    </table>
    </table>
    </table>
    </table>
    </table>
    </table>
    </table>
    </table>
    </table>
    </table>
    </table>
<!--  **Misc**  -->
     <table name="X"/>
     <table name="Y"/>
   </table>
</rom>
Thanks Golden, looks all good to me you have been a great help
All I have to do is work out how to play with the torque limiters in 1st gear now.
God these evo X are hard work.
Cheers
Lee
Old Aug 19, 2010 | 04:51 AM
grayw's Avatar
There is no 1st gear torque limit set on that rom ID, hence using it over the original FQ version.
Old Aug 19, 2010 | 11:47 AM
Dragon-V's Avatar
I have another X to do, this car has been ecutek'd so wondered how they worked in general.
Lee
richardjh
Sep 17, 2023 01:02 AM
pug206
Lancer Engine Management / Tuning Forums
Jun 7, 2017 03:17 AM
monkeyevo
Dec 3, 2015 10:22 PM
OttRalliart05
Dec 2, 2015 07:26 AM
turboback1243
Sep 27, 2015 02:38 PM
