Tune change needed with test pipe or not?
Old Sep 6, 2010 | 09:49 PM
pstl_pete's Avatar
Im currently running a COBB hi-flow cat but I want to switch over to my tomei test pipe for the track, I know I should have it retuned for optimal results but Im wondering if I just swap it out will it affect AFR in a negative way or cause a boost spike?
Thanks in advance.
Old Sep 7, 2010 | 03:21 AM
tephra's Avatar
well since your on a HFC at the moment it will probably be ok..
do you have a boost gauge to monitor boost?
Old Sep 7, 2010 | 04:58 PM
pstl_pete's Avatar
Yes I do, which I'll be sure to watch closely. I also have AFR that I'll monitor but I guess I just wanted to know for my personal sake of mind that if the tune can change dramatically enough to lean things out with a simple reducing in backpressue.
Old Sep 7, 2010 | 05:41 PM
tephra's Avatar
yes it will.
so depending how aggressive your current tune is you could be in for trouble..
Old Sep 7, 2010 | 09:04 PM
arghx7's Avatar
any time you change the level of restriction in the exhaust you can throw off your boost control
cla2000
Jul 25, 2016 04:04 AM
TxFAkuma
Jul 13, 2016 05:15 PM
joonvang
Jun 6, 2016 03:27 PM
infeKteDx
Jul 3, 2013 07:36 AM
ChrisBond1
Midwest Region
Apr 5, 2010 09:33 PM
