Random knocking in 5th gear when going to WOT
Old Sep 10, 2010 | 09:38 AM
AWDTerror's Avatar
So I was going to work this morning and was trying to pass someone on the interstate and I punched it in 5th @75mph @ 4200rpms, and the car (via Accessport) started showing some crazy knock. I only was on it for a sec when I let off because of it but it peaked out at 12.7CA, AFRs were at mid 11s. This is not the first time this has happened, it has happened a hand full of times before. It would happen once or twice then not happen for a while then just pop up again.
All other gears are fine and WOT from 4th going to 5th it doesn't happen.
Any ideas? I think it maybe related to the ECU transitioning to the WOT at speed.
Old Sep 10, 2010 | 09:54 AM
Tuxevo's Avatar
Could be your timing or it could be rolling into boost at a low rpm in a high gear. Although I would think 4200rpm would rule that out. Are you running a custom tune through your AP or a generic one?
Old Sep 10, 2010 | 09:58 AM
AWDTerror's Avatar
Off the shelf (generic)
Old Sep 10, 2010 | 10:33 PM
Yoo Shin's Avatar
That's common though I've never really heard of a solution or reason why. It was common in my WRXs and the MS3. I was always told never to go WOT in the top gear at any RPM.
Old Sep 11, 2010 | 06:53 AM
Golden's Avatar
You can WOT in 5th after you hit redline in 4th.
Check common stuff like relay, FPR vacuum line....
Old Sep 11, 2010 | 07:30 AM
AWDTerror's Avatar
lol yeah all that stuff has been checked. Even changed to a new set of spark plugs (OEM) didn't do anything.
Old Sep 11, 2010 | 05:17 PM
Jack_of_Trades's Avatar
Its not uncommon for the timing used in 3rd/4th that is knock-free to be an issue in 5th. Especially since boost can creep higher in 5th. Try to lower the timing in the problem area by 1* and see if its more consistent.
evo_gerard
Jun 1, 2014 08:04 AM
volcano
Sep 8, 2013 02:17 PM
ArchieBabes
17
Feb 16, 2013 06:11 PM
Windstorm
Apr 23, 2012 05:59 PM
GgreyEVOIX
15
May 1, 2009 02:41 PM
