Mitsu = Cheeky Buggers
Old Sep 16, 2010 | 06:25 PM
saytheb's Avatar
Looks like you lost 29.27 and gained -12.57!
Old Sep 16, 2010 | 07:10 PM
Golden's Avatar
You might want to check and see if there is 1 more column in the newer ROM.
I've seen them do that before.
(Sorry, had to quote the large image for reference)
Originally Posted by tephra
^ yes I think thats whats happening, but not on 3500/4000 - thats a ****LOAD of timing..
anyways more fun:
WTF!!!!!!!!!
Old Sep 16, 2010 | 07:26 PM
tephra's Avatar
yes I thought about that - and I have checked yet.
But the table would look ugly if the column was missing...
From my perspective (from what I understand) that means the 2011 will never be able to have higher than 248.3load.. Because above 21psi it will flatline out...
Old Sep 16, 2010 | 08:05 PM
tephra's Avatar
bastard... you are right.. extra column :|
Well that is a relief!
and it didn't screw up the table image because it was a column - extra row would have made it look ugly
Old Sep 17, 2010 | 05:07 AM
Clipse3GT's Avatar
Just a FYI, I tried the 2011 GSR Timing from 0-80load and 500-2000 rpm. It would give me a Misfire code on cylinder 4 to run such timing on 08 GSR. But this was a quick plug and play. I will play with it some more to see what I can do.
Old Sep 17, 2010 | 06:39 AM
Optiblue's Avatar
Very interesting. Mitsu is tuning more towards DD'ing then?
Old Sep 17, 2010 | 06:52 AM
mrfred's Avatar
seems strange that it took this long for mitsu to do this. are there any engine/hardware changes to the 2011?
Old Sep 18, 2010 | 02:35 AM
DEVOIX's Avatar
They also have changed spark plugs with the 2011
Old Sep 18, 2010 | 03:00 AM
mrfred's Avatar
Different geometry, heat range, brand?
Old Sep 18, 2010 | 03:57 AM
tephra's Avatar
we arn't aware of any spec changes...
probably is some thou.
we noticed:
1) electric fold in mirrors
2) USB connective in glovebox for non MMCS
3) some 1 wire connection going to "small componenet" bolted to intake...
4) some new fandangled centre console light thingy... possible alarm related..
Old Sep 18, 2010 | 08:41 AM
mrfred's Avatar
The component attached to the air intake sounds interesting.
Old Sep 18, 2010 | 10:25 AM
GST Motorsports's Avatar
we noticed:
#3 is on the USDM 2010's as well, if you are talking about the intake manifold.
- Bryan
Old Sep 18, 2010 | 02:43 PM
DEVOIX's Avatar
Originally Posted by mrfred
different geometry, heat range, brand?
dilkr8b6
Old Sep 19, 2010 | 06:02 PM
Beeble's Avatar
- Bryan
Yes on the intake mani. has a 2-pronged fork terminal joined to a small black box. Looks like it could be an earth?
Old Sep 19, 2010 | 06:22 PM
UT_EvoX's Avatar
Those appear on 2000 and earlier Mitsus as well - IIRC, it's so the ECU can measure the voltage difference (resistance) between the intake mani and its own ground source. At least, that's what I think it was for.
