Mitsu = Cheeky Buggers
Lol.
So I got sent a 2011 AUDM ROM.
LOTS of changes.
1) MIVEC, looks a lot more like how we do it now, lots of ex-retard in cruise, lots of in-advance in usual areas
2) Timing, a lot more in cruise, a bit less up top, lots more idle timing and lots more overrun timing
3) Fuel Map is a LOT richer
3.1) AFR Calibration map is a LOT leaner
I havn't even got to the boost maps yet...
So quite a LOT of changes over 2008/2010..
I suspect you guys will see the same thing with the 2011 ROM's
ps - Our 2010 could flash onto 2008... Not anymore with the 2011 -> 2010/2008... (Like your 2010 -> 2008 is no good)
LOTS of changes.
It's very odd that they keep lowering the upper bound map. It's not like anything ups timing. So it should just run what is in the timing map. Unless they are trying to save the car from crappy tuners.
oh I can confirm that reading/flashing works fine.
we had a weird issue with AFR thou.. Copied across the fuel maps + calibration map (injector scaling/latencies/maf scaling where the same) and it was 9.5AFR... Car made the right power thou..
*shurg*
*shurg*
