Maximum Safe Timing
Exactly how much you need to adjust your knock sensitivity is up for debate. How much timing you can run, as tephra posted, subject to many variables, not even counting fuel quality (boost level, afr, exhaust back pressure, cylinder head condition, spark plug, just to name a few). If you run your car this close to the edge, then one marginal tank of gas, or change in weather conditions, puts you over the edge. You do not want to be there.
If you want to adjust your knock sensor to get it to stop pulling timing for noise, use some method besides or in addition to evoscan knock count to determine if you are having real knock or not.
blackonblackevo
27
Jun 2, 2007 03:38 PM
