What all do I need to run e85?
Old Oct 19, 2010 | 06:16 PM
socalrallired09's Avatar
Hello everyone I recently moved to tennessee/kentucky and e85 is alot more accessible to me now and I want to know everything that Id need to run e85. Im currently running the following setup just in case the info is needed. AEM intake, Injen uicp, ams widemouth dp, ams resonated tp, dc sports single canister catback and tune. Thanks all info is appreciated.
Old Oct 19, 2010 | 06:22 PM
milford's Avatar
larger injectors. walbro. ethanol. tune
Old Oct 19, 2010 | 06:25 PM
what size injectors? 800, 1000? Im still running the stock turbo but will be eventually upgrade? thanks
Old Oct 19, 2010 | 06:35 PM
iEvoX's Avatar
Hope this helps! Its very informative
https://www.evolutionm.net/forums/ev...iscussion.html
Old Oct 19, 2010 | 06:47 PM
sweet thanks I just got a qwik class in e85 I appreciate it
Old Oct 19, 2010 | 06:57 PM
kozmic27's Avatar
Really short version.
The ability to bring 30% (minimum) more fuel to your combustion chamber than your target horsepower requires on gasoline.
Old Oct 20, 2010 | 09:53 AM
fostytou's Avatar
EvoM Community Team
Yeah, this can pretty much get closed down now....
Just make sure you use e85 safe lines when you run the fuel pump. The stock fuel pump is actually pretty capable, but the internal filter sock on it can break down in e85. The factory siphon line (and older UR line) can both break down a little in it also.
I run the blaqops kit, but you can also just make your own.
Old Oct 20, 2010 | 10:43 AM
MACKLIN's Avatar
So many threads on this just search
Old Oct 20, 2010 | 05:57 PM
aftershock141's Avatar
A brain.
Old Oct 20, 2010 | 08:08 PM
RunningRings's Avatar
L M A OOOO!!
Originally Posted by aftershock141
A brain.
Pure Playaer
Feb 27, 2015 02:41 PM
DEREK199574
16
Jul 14, 2014 08:28 AM
PlanoEvo
E85 / Ethanol
Mar 18, 2009 10:52 AM
rogueXevolution
E85 / Ethanol
Jan 4, 2009 06:57 PM
