Upper/Lower Bound Map for 54070007
Thanks!!!
Code:
<scaling name="Min timing" units="degrees" toexpr="x-20" frexpr="x+20" format="%.0f" min="-61" max="61" inc="1" storagetype="int8" endian="big"/> <table name="Lower Bound Ignition Timing" category="Timing" address="50799" type="3D" level="2" swapxy="true" scaling="Min timing"> <table name="Load" address="613a8" type="X Axis" elements="21" scaling="Load"/> <table name="RPM" address="6135c" type="Y Axis" elements="16" scaling="RPM"/> </table> <table name="Upper Bound Ignition Timing" category="Timing" address="607d9" type="3D" level="2" swapxy="true" scaling="Timing"> <table name="Load" address="60fd6" type="X Axis" elements="22" scaling="Load"/> <table name="RPM" address="60fa2" type="Y Axis" elements="23" scaling="RPM"/> </table>
tephra
44
May 17, 2021 03:38 AM
Hiboost
15
Jan 10, 2016 10:15 PM
