A better Speed log item
Old Nov 3, 2010 | 08:08 PM
tephra's Avatar
Hi All,
So the regular SPEED (MUT2F) is a bit slow to update.
If you use MUT2E and divide by 4 that should give you a much smoother update interval...
When I get a chance I will post up a graphy graph
Cheers
D.
Old Nov 4, 2010 | 09:03 PM
Beeble's Avatar
mine tops out at 63.5
evoscan and standalone
that's using x/4 or (x,0.25,*)
Old Nov 15, 2010 | 12:02 AM
Beeble's Avatar
anyone else tried this yet??
Old Nov 15, 2010 | 01:14 AM
merlin.oz's Avatar
no, bu.t maybe its a 2-byte and you are only seeing the first 8 bits
Old Nov 15, 2010 | 09:12 AM
derekste's Avatar
probably seeing the least significant bits/byte... try changing "ResponseBytes" to 2 in EvoScan and see if that fixes it.
Old Nov 15, 2010 | 11:37 PM
Beeble's Avatar
good thought, I'll give that a go
Old Nov 16, 2010 | 07:27 AM
mrfred's Avatar
the low byte of a 2-byte value will roll over to zero each time the high byte increments.
chmodlf
Aug 31, 2018 01:38 PM
Jack_of_Trades
May 29, 2018 07:05 AM
Gormless
Jun 3, 2012 07:22 AM
Seijuro
Mar 20, 2010 11:53 AM
2k4EvoVIII
Sep 18, 2008 04:27 AM
