royally screwed with AEM UEGO and PERRIN TBE
Hi Guys - well it looks like I'm pretty screwed here. I've been asking around about this setup but nobody really warned me about the PERRIN catback not having an extra o2 bung for the wideband, as well as the UEGO sensor not being narrowband compatible to the stock ecu. so now what? (as in, i could've gone the route of going with a DP that has an extra bung, or purchased a wideband that can simulate NB). anybody care to help me out with this unforunate situation? thanks..
there is a bung before the cat and after the cat on the downpipe. 2 bungs. not three.
what if i were to replace the post-cat sensor with the wideband? it'll throw a cel but i can live with that, for the sake of being able to monitor AFR. thoughts?
that was supplied by who. mitsubishi? mitsubishi only supplied two bungs. one's precat (needed for nb) and the other is postcat, which needs to be disabled as to not damage my wideband sensor. so what the **** are you talking about.
I had one put in for my wideband just like pretty much everyone else did. There are very few aftermarket options available that have the extra bung already installed in the pipe because the tuner or shop usually decides where to put it. The companies that make the aftermarket parts don't know your setup hence why almost all wideband gauges come with a bung to weld into place for installing. Hope that helps and good luck.
Is the exhaust already installed? If not, take the TP/HFC to a hole-in-the-wall muffler shop, and pay $10-15 to have the bung from the UEGO welded in. If it is already installed, do the same thing, only pay a little more to have it put on a lift.
