AMS Tested Motec PnP Evo X
Old Jan 15, 2011, 12:58 PM
Robevo RS's Avatar
Originally Posted by BlackTrack
Haha I was joking. I just wanna try tweakin the diff on it soon!
would you let me know how is that worked?
Old Jan 15, 2011, 02:39 PM
bigmiketino's Avatar
Very nice motec rocks..
Old Jan 17, 2011, 06:54 AM
Chris@AMS's Avatar
Originally Posted by LapDance
Does it have instant map changing capabilities? As in a failsafe map for running meth.
YES, that is something that can be done.
It can even be set up as a failsafe or a switch which you can have two separate power maps on. A full tuned pump gas/no meth, and a fully tuned pump gas/meth map.
The possibilities are almost limitless
Old Jan 17, 2011, 07:03 AM
LapDance's Avatar
Thats exactly what I'm looking for. I know its pricey but could you pm me some figures?
Old Jan 17, 2011, 10:32 AM
Chris@AMS's Avatar
Dan will be getting back to you shortly with the info you need
Old Jan 20, 2011, 10:03 PM
mrfred's Avatar
what do you know or can tell us about the knock control algorithm?
Old Jan 29, 2011, 09:50 AM
kozmic27's Avatar
I would immagine that this unit would support any function that the Motec units currently support wich is just about everything you can immagine. The real issue in getting a plug and play set up is pre-calibrating all of the sensors to the unit, and the wiring harness. This is not as simple as it sounds.
So the question is, how much arm twisting will it take you to get motec to support the sst......?
Old Jan 31, 2011, 06:10 AM
Chris@AMS's Avatar
The good thing about these boxes however is that they are plug and play. No wiring necessary, though a few pins will need to be added for the CAN comms, and the lambda should you choose to use it. The system comes with a base file in it that already has the sensors calibrated. The standard calibration that comes with it is currently going through some revisions as well, and it will be almost completely bolt-in for a car with minimal modification.
As mentioned previously, you can have individual cylinder knock control if you wish, and also tune the frequency band and length of time you are using for your knock data collection. As with the ECU, it is advanced as you want it to be, or advanced as the user can handle.
Old Feb 10, 2011, 04:53 AM
amsevoixmrse's Avatar
subscribed !
Magnumpsi
For Sale - Cars For Sale
Mar 16, 2014 11:12 AM
Magnumpsi
Feb 5, 2014 04:03 PM
Vivid Racing
23
Jun 3, 2010 09:46 AM
Vivid Racing
23
Apr 21, 2010 10:05 AM
Magnumpsi
Mar 8, 2010 01:15 PM
Quick Reply: AMS Tested Motec PnP Evo X
