Choppy power band on stage 1 :/
Old Jan 2, 2011 | 04:01 PM
HELPr's Avatar
After driving around with the Cobb Ap, ETS intake, and Buschur upper pipe im a little dissapointed in the way the power feels, although I didnt expect much in the way of gains from these mods, I expected a little more than what I got i suppose. I mean stage 1 is rated at a 19% increase in power, thats almost 55hp granted only 40 will probably be seen at the wheels.. anyways, When I accelerate there is a drop at about 4-5k and from that point it feels wavy for lack of better words, this is especially noticable in 3 and 4th where you move throught the band a bit slower. Anyone else have this issue?? BTW Im runnig the Cobb SF Stage 1 map as the ets and SF systems use a very similar set up.
Old Jan 2, 2011 | 09:32 PM
Octane Blue's Avatar
It'd help everyone out if you'd upload a log replicating whatever you're having problems with. Little difficult to diagnose your problem with the amount of info you have given.
Old Jan 3, 2011 | 09:03 AM
fostytou's Avatar
EvoM Community Team
Choppy sounds like a too-rich misfire, wavy sounds like its shooting above and below the boost target because it is over correcting too much.
Are there any pops / booms when this happens? Do you see any knock?
Monitor AFR, knock, and boost while it happens and report back.
Old Jan 4, 2011 | 06:30 PM
HELPr's Avatar
Hey Man, hows it going?
Hmm will do, ill see if I can monitor AFR with the AP, but I dont believe I saw it on the monitor screen.
It doesnt pop or boom and there is not knock that is noticable
Old Jan 5, 2011 | 06:53 PM
HELPr's Avatar
Here is the Datalog of a 3rd gear pull, peak boost was logged at 21.8
this is the Stage 1 93 Cobb SF intake map, and I am running the flash, buschur uicp, and ets intake.
Hope this helps, 21.8 seems a bit low, stock is 22 isnt it?
let me know what else I can do to help
-J
Old Jan 5, 2011 | 09:53 PM
fostytou's Avatar
EvoM Community Team
You never attached anything...
Old Jan 6, 2011 | 04:40 PM
HELPr's Avatar
Sorry didnt have it zipped the first time.
File Type: zip
3VOIXMR
Cobb AccessPORT
Sep 8, 2017 06:57 AM
dw0095
Cobb AccessPORT
Jul 12, 2013 11:08 AM
deadbeatrec
Cobb AccessPORT
Apr 30, 2013 04:28 PM
initialdrew
Dec 14, 2012 03:57 AM
walkerkd
20
Jan 31, 2011 06:24 PM
