Idle timing
Old Jan 8, 2011 | 04:49 AM
xhomm02's Avatar
Idle timing
Hi guys,
what idle timing do you run on the X? I tried to change from 10 to 20 timing advance without noticing any difference in idle stability (light hesitation sometimes). What is your experience?
Old Jan 8, 2011 | 10:05 AM
E6-X's Avatar
why would you want a higher timing during idle ?
well unless u have cams . . .
Old Jan 8, 2011 | 12:10 PM
xhomm02's Avatar
Stock cams, just wanted to try if it can make the idle smoother. Doesn´t look like.
Old Jan 10, 2011 | 07:48 AM
fostytou's Avatar
EvoM Community Team
20 is way too high. Use MIVEC adjustments and *maybe* add 3-4* to idle.
Old Jan 10, 2011 | 10:15 AM
RazorLab's Avatar
Something that will really blow your mind is that the 2011's have 26-30* in the 500 to 1000rpm and 0-20 load region, oem.
Old Jan 10, 2011 | 10:24 AM
Golden's Avatar
2011 Timing map from a USDM GSR
Old Jan 10, 2011 | 10:29 AM
RazorLab's Avatar
Golden/razorlab tag team
Old Jan 10, 2011 | 11:01 AM
fostytou's Avatar
EvoM Community Team
Well oh snap, call me Shirley. Without some serious MIVEC / head flow adjustments won't that result in insanely high idle EGTs?
Old Jan 10, 2011 | 11:14 AM
xhomm02's Avatar
Yes, this makes me crazy (I saw it before)... 10 or 26 degrees is pretty big difference, is there anything else changed (MIVEC)?
Old Jan 10, 2011 | 01:01 PM
Golden's Avatar
I know someone named Shirley... he's a lot smarter than you. It would be a compliment.
Old Jan 10, 2011 | 02:43 PM
fostytou's Avatar
EvoM Community Team
Hey, thats a last name! LOL, I wonder if our fearless mod-leader-programmer has ever seen Airplane / caught flak for it for weeks.
Old Jul 9, 2014 | 02:04 PM
xFonts's Avatar
Has anyone found the table for this on the 2011+? I want to add 1-2* at idle. The HOTM doesn't actually effect idle timing as its always at 10* during stock idle RPM. I *could* adjust the Idle compensation map to do it, but I'd rather change the actual target and use the compensation map as a - compensation map.
Old Jul 15, 2014 | 10:04 PM
Hiboost's Avatar
I ended up flashing my 2011 down to a 2010 rom so any changes to the timing values actually effect it. The main reason I did it was to allow use of the TephraV1 at the time. Not sure if you can bench flash a 2013 down to a 2010 to get the same effect but it might be an option.
browningderek
AEM EMS
73
Mar 2, 2019 08:35 PM
Evo47
May 4, 2015 08:53 PM
hurdle18
Feb 23, 2015 07:26 AM
OPENA(671)
Sep 5, 2013 09:54 PM
widge
May 11, 2010 07:16 AM
