Can I log correct MAP at high load?
Old Jan 25, 2011, 05:58 PM
tephra's Avatar
no as far as I know.
Old Jan 26, 2011, 04:04 AM
crimson red's Avatar
tephra,
Thank you for the info. I think that without temperature compensations, certainly the Airflow tables are not much useful.
Even without temperature compensations, if we could switch some sets of the Airflow tables as temperature goes hotter/colder, these tables would be a little more useful than now.
Old Jan 26, 2011, 04:32 AM
tephra's Avatar
I guess you could..
if you could be bothered
Old Jan 26, 2011, 08:41 AM
Golden's Avatar
Does exceeding the airflow tables do anything other than trip a code?
I guess I don't understand why you wouldn't just disable the tables and be done with it.
Old Jan 26, 2011, 09:32 AM
RazorLab's Avatar
Received 1,044 Likes on 762 Posts
If it puts the car in limp mode it will restrict WGDC to 0%, wastegate boost and cuts throttle percentage depending.
I agree with you and Tephra, there is really no reason *not* to disable these. The notion that these are safety features is absurb in my book. Tune the car correctly and there are other safety nets that Evo's all before the 10 have been using just fine.
If anything, these can become a liability, go to pull out into a main street and see a 5 ton truck coming your way, you step on it from low RPM, higher gear, and pop, limp mode. You aren't getting out of that trucks way very quickly at wastegate boost and cut throttle percentage.
Old Jan 26, 2011, 02:36 PM
merlin.oz's Avatar
100% agree with Byran and tephra on this, disable the damm things and get on with the tuneing.
They are just an ongoing liability, which can leave you or your missus in a BAD place with no power/escape clause.
Old Jan 28, 2011, 04:11 AM
I'm happy getting comments and advices from tephra, Golden, merlin.ozm, kozmic27, COBB Tuning, razorlab. Thanks gurus, I was too worried to disable it.
I've just turned it off.
merlin.oz,
I'm glad given your advice directly. I'm still translating your guide. It helps me a lot.
As you and razorlab say, occurring in some situations, it's very dangerous.
Last edited by crimson red; Jan 28, 2011 at 07:43 PM. Reason: added forgotten name and sentences
tephra
Jun 23, 2022 09:46 PM
211Ratsbud
Jan 17, 2022 03:01 AM
06Black
Jul 6, 2016 12:43 PM
ThEHiTMaN
Sep 4, 2007 02:38 PM
tkklemann
Aug 7, 2007 07:17 PM
Quick Reply: Can I log correct MAP at high load?
