stock solenold connector
Old Feb 12, 2011 | 08:29 PM
crimson red's Avatar
Question stock solenold connector
Hello 3-port guys,
I have a 08 jdm EvoX GSR and I just bought a tactrix 3-port with evo harness. It reached safely 2 days earlier. (I was surprised there ware no papers at all. Which port has which role? Which port should connect to where? No informations at all!! OMG! |o|)
Today, I tried to connect the power connector but I couldn't.
The harness which tactrix sent to me was not fit to my car's brown power plug(for bworn stock solenoid) shape. Perhaps I took any mistake but I want to confirm that the usdm connector has exactly same shape. Thank you.
-> I could. It's my fault that I connected incorrectly. CEL eliminated.
Here is the 08jdm brown power plug for brown(active) solenoid:
Here is the 08jdm stock brown(active) solenoid:
Old Feb 13, 2011 | 01:53 AM
tephra's Avatar
the tactrix cable/harness needs to be slightly modified.
you will see that there is a plastic tab that prevents it from inserting in either the black or brown plug....
I think its the brown plug you need, but not 100%!
just set both reactive to 50% and the passive to 0%, you should be able to tell straight away if you got the wrong plug
Old Feb 13, 2011 | 03:38 AM
tephra,
Thanks to the info. I shaved the prominence of the harness. It fits well now.
Thanks to you, I'll be able to tune the active wgdc tables next Sunday.
Old Feb 13, 2011 | 04:07 AM
tephra's Avatar
good job!
you know to start low and work upwards right?
ie depending what actuator you have start with 50% (or lower for a higher bar actuator) and do a run to make sure you dont overboost...
and zero out passive (until you are 100% sure the 3port is not connected to the wrong connector)
Old Feb 13, 2011 | 11:09 AM
RazorLab's Avatar
Yes, brown plug for the 3D reactive tables.
Old Feb 15, 2011 | 04:54 AM
tephra,
Yes, I've read Golden's thread and he gave me the same advice for protect my motor from overboost. Thank you.
I did that and the active solenoid works well.
good job!
razorlab,
now I'm sure I connected to the right connector. thank you.
jordantii
May 20, 2012 07:22 PM
Methodical4u
Evo X How Tos / Installations
15
Jul 8, 2010 04:43 PM
Clipse3GT
22
Jan 11, 2010 09:47 PM
CatalystGod
34
Mar 5, 2009 09:26 AM
EvoIXMR
Aug 4, 2008 08:06 AM
