Can someone explain (timing related Q)
Old Feb 27, 2011 | 06:32 PM
Clipse3GT's Avatar
Maybe when cold the engine needs a bit more advance to bring heat in and seal the piston rings bring the pressure up and up to operating temp a bit quicker. Or when the engine is cold it can't ignite fuel as well with lower timing.
Old Feb 27, 2011 | 07:00 PM
tephra's Avatar
Originally Posted by Golden
Isn't this the map that controls that?
(for the 2010 maps)
<table name="Percent Low Temp Timing Trim vs Coolant Temp" address="561bc" category="Timing" type="2D" scaling="Percent255">
<table name="Engine Temp" address="61310" type="Y Axis" elements="8" scaling="TempFarenheit"/>
</table>
No that is another one..
Old Feb 27, 2011 | 08:35 PM
tephra's Avatar
Sure its overly simplified and doesn't explain WHY, but at least we know it does it
Old Feb 27, 2011 | 08:38 PM
tephra's Avatar
Got another table:
This one seems to be linked to a MAFHz Accumulator, absolutley no idea, but it looks like it is activated when the MAFHz accumulator sees 1800 grams of air (yeh weird)
I havn't worked out the interval for the collection period yet...
Old Feb 27, 2011 | 09:44 PM
tephra's Avatar
Well I think that map is ONLY used when the engine isn't upto temp yet...
So we can pretty much ignore it
Old Feb 27, 2011 | 10:22 PM
tephra's Avatar
This one is VERY interesting, there are two tables, but they look similar.
I am not really a fan of the +20*..
Seems to be applied when Actual MIVEC Exhaust is greater or less than the value in the map...
Might be the source of our low load knock bryan?
Old Feb 27, 2011 | 11:42 PM
tephra's Avatar
ok... There are 4 tables, 2 for Intake 2 for Exhaust MIVEC.
Basically the ECU works out if the Actual Exhaust MIVEC is less than or greater than the Map Exhaust MIVEC.
Same for Intake MIVEC
Once it chooses which table to get the data from it then multiplies the actual difference by whatever the map lookup results in then divides by 0xA00
THEN it applies that as an ignition timing compensation...
ie, if you had 5* different between actual and map for the exhaust then it would be:
(5 * 32) * (whatever is in these 4 maps, ie 20*) / 0xA00 = 1.25*
so your timing would go up or down 1*
now this doesn't seem to be very much, but I just dont like the looks of these 4 tables:
The values just seem so random, 20 with 0's on either side...
I am thinking of zero'ing out these tables
Old Feb 28, 2011 | 12:31 AM
tephra's Avatar
Hrmm
Bryan your maps are already zero'd out.
I emailed you the def's..
a quick look at 52690022 shows they are similar to mine.. as is 2011 Au Evo.
MR vs GSR same thing almost..
Why the difference for RA vs Evo??
Old Feb 28, 2011 | 07:53 AM
Golden's Avatar
Different cams stock?
Old Feb 28, 2011 | 10:04 AM
RazorLab's Avatar
(for the 2010 maps)
</table>
Every time I change that table it ends up triggering a P050B
Old Feb 28, 2011 | 10:06 AM
RazorLab's Avatar
Originally Posted by tephra
Got another table:
That sure looks just like the cold ignition retard table(s) from Evo 8/9
Old Feb 28, 2011 | 11:43 AM
Golden's Avatar
Does it idle better when cold?
When I zero out that table, my car runs a ton better in the cold when ECT < 120*F.
Old Feb 28, 2011 | 11:55 AM
RazorLab's Avatar
Yup works great on evo 8/9.
I put it back to OEM values on my RA because I was sick of getting the CEL.
Do you not get a P050B? The RA's seem to get it when tweaking that table.
Old Feb 28, 2011 | 07:28 PM
Golden's Avatar
No I don't get it. I did it to a 2010 RA that I'm tuning. He is running an AP. I don't think he is throwing any codes. I'll double check.
Old Feb 28, 2011 | 07:37 PM
Golden's Avatar
Just checked.. no CEL after a week or so.
