Can someone explain (timing related Q)
Old Mar 1, 2011 | 07:40 AM
  #31
Clipse3GT's Avatar
Originally Posted by tephra
ok... There are 4 tables, 2 for Intake 2 for Exhaust MIVEC.
Basically the ECU works out if the Actual Exhaust MIVEC is less than or greater than the Map Exhaust MIVEC.
Same for Intake MIVEC
Once it chooses which table to get the data from it then multiplies the actual difference by whatever the map lookup results in then divides by 0xA00
THEN it applies that as an ignition timing compensation...
ie, if you had 5* different between actual and map for the exhaust then it would be:
(5 * 32) * (whatever is in these 4 maps, ie 20*) / 0xA00 = 1.25*
so your timing would go up or down 1*
now this doesn't seem to be very much, but I just dont like the looks of these 4 tables:
The values just seem so random, 20 with 0's on either side...
I am thinking of zero'ing out these tables
I agree, I think zeroing out this table would be beneficial.
I see now need for these random values or how they would actually help at all...
Old Mar 1, 2011 | 09:41 AM
  #32
RazorLab's Avatar
Originally Posted by Golden
Just checked.. no CEL after a week or so.
Interesting, how do you have that table set?
I changed them for the RA Basemaps and everyone that used it started getting P050B's, but it back to OEM values and all gone.
Old Mar 1, 2011 | 10:51 AM
  #33
Golden's Avatar
All 0's.
In my car, I run E-85 and when the ECT is cold, it runs very nice with those settings. Before I zeroed out the table, it would hesitate / miss a bunch when cold. My wideband would go massively lean and the engine would feel like it died. Now, it runs perfect when cold.
I used to have to warm it up to 100*f before it would drive normal. Now I can drive it much colder if I have to. I normally like to warm it up though.
Old Mar 1, 2011 | 10:58 AM
  #34
Golden's Avatar
Screen shot - 2010 RA is the ATR table; 2010 GSR is the EcuFlash table (my car)
Attached Thumbnails Can someone explain (timing related Q)-ignitionwarmup.png
Old Mar 1, 2011 | 11:12 AM
  #35
RazorLab's Avatar
All 0's.
Yea I know how well it works, I have it zeroed on my Evo 8.
On the RA, if i zero it or even half it, I throw the P050B.
Old Mar 7, 2011 | 07:57 AM
  #36
tephra's Avatar
you guys might be talking about different tables.
there are two that are the same size and very close in values.
maybe post up your addresses to confirm
Old Mar 7, 2011 | 08:14 AM
  #37
toaster032's Avatar
cold air is denser, which means there's more of it to use during the combustion cycle....principle #1 of turbos
Old Mar 7, 2011 | 01:54 PM
  #38
Golden's Avatar
The table I am talking about is at:
52680015 50793
555x000x 507a5
Old Apr 5, 2011 | 07:27 AM
  #39
derekste's Avatar
any updates on this? I suffer from excessive timing retard until coolant temp rises just a little bit... car falls flat on its face and goes lean, and I believe it is related (I knew there were more coolant related timing maps than met the eye)
Old Apr 5, 2011 | 04:02 PM
  #40
merlin.oz's Avatar
Tephra, back to your original post question, warmup advance (adding), most aftermarket engine management have a 2D table to add timing when the coolant is low.
I believe it is to help with the slower burn rate of gasoline when cold.
Adding advance when cold certainly has hepled in these circumstances, so I was always curious as to why a corresponding table was not found in our ROMs.
Seems like it was there all along - will have to start searching again I guess.
Old Apr 12, 2011 | 08:21 AM
  #41
mrfred's Avatar
there is a cold engine ign timing adder table. its been know and defined for a few years in several of the usdm roms.
Octane Blue
Jul 10, 2014 05:02 AM
maevo8
10
May 9, 2012 01:30 PM
evo8jedi
For Sale - Cars For Sale
10
Feb 5, 2011 03:48 PM
Appauldd
Mar 2, 2009 03:49 PM
