Boost only @ 17-19psi max?
Old Mar 1, 2011 | 07:26 PM
HPEVOX's Avatar
Hey guys I am currently running the Cobb AP with Stage 1 injen intake for 93 octane. I am only able to hit about 17-18 psi in 3rd and 4th @ WOT and 18-19 in 5th @ WOT. Any recommendations on what this could be noting that Cobb shows boost target levels at approx 24psi with this particular tune.
Mods- Inj intake, hard UICP+LICP, ETS V2 CBE-stock DV
Thanks for the help guys!
Old Mar 1, 2011 | 08:38 PM
chetrickerman's Avatar
Veteran: Army
did you take out the boost pill?
Old Mar 2, 2011 | 01:08 PM
HPEVOX's Avatar
No Cobb clames you don't need to with the stage 1 tune. I was hitting approx 21 psi with the 91 octane tune running 93 octane fuel. Now with the 93 tune running 93 boost is lower. Also the temp is up about 20 deg from what it was.
Old Mar 2, 2011 | 04:22 PM
Veteran: Army
i would say it has to be something with the map.
otherwise, just in case, check all of your vacuum lines
Old Mar 3, 2011 | 11:30 AM
HPEVOX's Avatar
All the lines are good. May switch back to the other map and see what happens then i will know..I think it may be the hotter weather?
Old Mar 3, 2011 | 04:20 PM
Bear.914's Avatar
Do you have a boost guage ? Whats the vac showing ?
hmmm idk maybe try loading stock map, then back to the stg 1
Veteran: Army
i dont think so, because the turbo will just spin faster to send the same amount of air.
try the other map. see how that goes
Old Mar 4, 2011 | 06:52 AM
HPEVOX's Avatar
Vacuum is the same approx 19psi at idle with warm engine. When I get it back I may try uploading the 91 octane tune again and see how it does?.?. I just don't wanna pull that pill, but I may try it.
Old Mar 4, 2011 | 06:56 AM
Bear.914's Avatar
Find a similar vac line and use it this way the pill still remains inside the other one
Old Mar 4, 2011 | 11:30 AM
HPEVOX's Avatar
That was the plan! No way i'm trying to get it back in lol
Old Mar 4, 2011 | 05:17 PM
Veteran: Army
boost pills are not hard to get in and out of the lines. just use a metal coat hanger.
is your boost gauge a mechanical or electrical?
Old Mar 5, 2011 | 11:56 AM
HPEVOX's Avatar
Its the AEM digital boost gauge. Seems to be very accurate with other peoples readings as well. The Cobb AP doesn't read same boost levels. AEM is vacuum line to a pressure sensor then wiring to back of gauge. Works well.
Old Mar 5, 2011 | 12:23 PM
Veteran: Army
yea, so that gauge is electric. I have a mechanical and im not getting quite 19 hg.
btw, vacuum is measured with inches of mercury
Old Mar 5, 2011 | 01:33 PM
HPEVOX's Avatar
My idle is usually 18-20 with no AC or anything on. Up to 16 with AC on. Cobb reds like -9 or so. Theres been discussions about vacuum reading being wrong on the AP. I'm just ready to get it back from paint! lol then I can actually get it done haha
Old Mar 5, 2011 | 07:07 PM
RevMoto's Avatar
If you aren't hitting your desired boost level chances are you have a boost leak. Do a boost leak test and you will surprise yourself.
