Evo X Starting Issues
Old Apr 2, 2011 | 12:34 PM
myearwood173's Avatar
Hi guys i live in the UK with a Evo X running 450 BHP fully forged as well, anyway went to the petrol station to get fuel went to start the and it didn't start first go, second time it did but had to use my throttle pedal as well, has happened before in different places, is it my relay? Can you guys me??
Old Apr 2, 2011 | 12:39 PM
KyleH's Avatar
Is it only when you're filling up with fuel, or does it ever happen on other "short" stops of similar duration? Have you ever replaced the factory relay? If you have an 08 (not sure about 09+) there's no reason to not have done that already. There are ample threads and discussion about it.
Old Apr 2, 2011 | 01:54 PM
Hi No does it at different times not just filling up with fuel, Also 2008 i have not replaced the factory relay, can you please advise me what relay?
Old Apr 2, 2011 | 04:52 PM
ikuto's Avatar
Also check your MAF sensor. My car decided to not start one day and it turned out to be that. Swapped it with my friend's MAF and fired right up after going through the trouble of checking for spark and fuel. It also started having trouble starting up before that every now and then where it would want to stall at idle until I give it some gas to stabilize it.
Old Apr 3, 2011 | 07:52 AM
KyleH's Avatar
Multiple threads on fuel pump relay. You should take care of this immediately, even if it isn't your source of issue on this particular problem. At least take it out of the equation.
https://www.evolutionm.net/forums/ev...-page-4-a.html
https://www.evolutionm.net/forums/ev...ur-engine.html
https://www.evolutionm.net/forums/ev...relay-tsb.html
Besides this... what sort of programming upgrades are you running?
Old Apr 3, 2011 | 02:57 PM
JC7119's Avatar
Before I got rid of my Evo X, I had the same problem, ended up in a mitsu dealer in Salt Lake City Utah with a dead starter
Old Apr 4, 2011 | 12:50 AM
xhomm02's Avatar
On cold or warmed up engine or no matter?
Old Apr 4, 2011 | 03:29 AM
xbaybiixsophx's Avatar
myearwood173, its sophia-x from the mlr , i had the same problem, mitsi gave my battery a full charge when it was last in, and it seems fine now, as soon as i got my car i bought the blue upgraded fuel relay and never had a problem with that in my 2 months ownership now , the panasonic batterys are pants....thats what was causing my problem
Old Apr 4, 2011 | 07:24 AM
fostytou's Avatar
EvoM Community Team
I'm assuming you have aftermarket injectors. Make sure your startup injector pulse width tables are tuned properly also.
Old Apr 4, 2011 | 12:57 PM
Hi Sophia so was it your relay the problem or the battery?
I've just ordered 4 Blue Relays as well as a mfi one too from JNZ Tuning
I didn't know you was a member on here as well?
Thanks Matt.
Old Apr 4, 2011 | 12:59 PM
Only warmed up engine, but doesn't do it all the time, only when the car feels like doing it
Old Apr 5, 2011 | 03:07 AM
Thanks Matt.
it wasnt the relay, it was my battery, they said the charge was really low , relay was replaced before i was even insuredon the car lol, try changing the battery or getting it replaced under warranty iv been on here for a while these lovely americans know their stuff lol sophia.
Old Apr 5, 2011 | 10:41 AM
Hi Sophia,
Yeah they should do know there stuff .
I will try and get a new battery under warranty
Thanks again Matt.
PICASO83
Jan 13, 2014 02:23 PM
AngryEvo8
Apr 29, 2013 08:26 AM
new2Lance
Mar 29, 2012 09:09 AM
ron2003
Aug 5, 2011 10:16 PM
EvoX6436
Middle East Forum
Feb 17, 2010 01:56 PM
