Need some help!!!! Evo 8 problems
Old Jan 13, 2014 | 08:25 AM
PICASO83's Avatar
i was driving ther car messing around a lil with it during the rain!!!happy!!!! when the clock on the fuel rail broke off....any ways I fixed it and now the car will not stay on!!!! it starts but it keeps shutting off even when I hit the gas pedal the car chokes and shuts off!!!! any advice from the experts??? maybe the fuel pump went???? pls ppl hel p out ??
Old Jan 13, 2014 | 08:32 AM
Shade08's Avatar
Dude, seriously? Drinking and driving isn't cool.
Old Jan 13, 2014 | 08:43 AM
Biggiesacks's Avatar
Damn cheap fuel rail clocks.... this would be a good time to upgrade to a pebble, you can get them with some cool skins.
Old Jan 13, 2014 | 08:49 AM
DSMdynamic's Avatar
Old Jan 13, 2014 | 08:50 AM
PICASO83's Avatar
I"ll def look into that!!!! but right now I need some ideas of what the problem can be??
Old Jan 13, 2014 | 09:15 AM
Ev0ikon's Avatar
Originally Posted by DSMdynamic
When a facepalm won't do.
OP: What is a fuel rail "clock". And I am scare to ask what "skin" means.
Old Jan 13, 2014 | 09:24 AM
PICASO83's Avatar
CLOCK"" the pressur egauge the elbow broke off and the fuel started to leak out!!!
Old Jan 13, 2014 | 09:31 AM
BaconNinja's Avatar
Not sure what the "clock" is. Do you have pictures? Post some pictures or describe exactly what you broke and how you "fixed" it.
Old Jan 13, 2014 | 09:34 AM
stvn87903's Avatar
^ I love this.
A pebble is a watch designed to connect to a smart phone via bluetooth.
You can download new skins on your phone and change the face of the watch. It has nothing to do with a car.
https://getpebble.com/
Old Jan 13, 2014 | 09:46 AM
Ev0ikon's Avatar
Ok. Now I got it.
So, is the gauge showing any fuel pressure at idle?
Old Jan 13, 2014 | 09:55 AM
PICASO83's Avatar
Ok. Now I got it.
car will not stay on so it doesn't idle......car starts but shuts right off.......if I play with the gas......the rpm jumps but it drops and car shuts off........the pressure gauge when ignition is on shows less than 10psi......but when the car starts for like 5 seconds it jumps to 42psi......but it will not stay on...so I cant really check fuel pressure to see what exactly is at
Old Jan 13, 2014 | 10:08 AM
timasse's Avatar
Well bro, I think your car has a problem.
bjessup's Avatar
The only issue I've had like this was my IAC valve. Not necessarily the issue but could be something to check?
Old Jan 13, 2014 | 11:47 AM
stvn87903's Avatar
How did you 'fix' the gauge on the fuel rail?
Did it pull the threads out when it fell off?
Does it leak at all now that it's fixed?
Do you have an aftermarket fuel pressure regulator?
If so, is your vacuum line still connected at both ends?
Old Jan 13, 2014 | 02:23 PM
PICASO83's Avatar
I pulled out all the threads in there .......I do have an after market reg.....all lines are connected....no leaks at all!!!!! all lines are c onnected.....
evojmj85
Lancer Troubleshooting
Dec 28, 2015 08:46 AM
ppremier21
May 25, 2012 09:56 AM
new2Lance
Mar 29, 2012 09:09 AM
ron2003
Aug 5, 2011 10:16 PM
nscahall
Mid-Atlantic Region
Jun 24, 2010 01:34 PM
