AFE/Takeda intake, Cobb map?
Old Jul 7, 2011 | 10:06 PM
import111's Avatar
I am really wanting an AFE intake but I also want to run a Cobb OTS stage 2 map. They say MAF readings can very from intake to intake and that I should watch my fuel trims if I decide to run the AFE intake with 1 of the other intake + stage 2 maps.
Anyone run an intake not on Cobbs list of intakes on their maps and look at readings to see if there was any problems? It uses the stock MAF pipe so I would think you could use any other map for a stage 2 + SRI cone filter intake with stock MAF pipe.
Old Jul 7, 2011 | 10:43 PM
BakaUnchi's Avatar
Try the SF intake mapping
Old Jul 8, 2011 | 08:06 AM
fostytou's Avatar
EvoM Community Team
Also, please search... There was literally a reply to this exact question 8 hours before you posted this:
https://www.evolutionm.net/forums/9443830-post8.html
Old Jul 8, 2011 | 01:43 PM
import111's Avatar
I did search, for days. No where in that post or any other post is there data logged info on what the A/F ratio, timing, knock, or anything else, running a Cobb map for a different intake. I need to make sure I would be safe running a Cobb SF or Injen intake map using the AFE intake for long term, track days, ect.
TurboNubCake
Jul 19, 2014 04:52 AM
Hotevo3
Cobb AccessPORT
Mar 31, 2014 01:28 PM
scheides
91
Jan 21, 2014 04:01 AM
The_X_Effect
Cobb AccessPORT
22
Aug 14, 2013 11:42 AM
