Lean-out issue around 3000rpm
Old Oct 11, 2011 | 08:04 AM
  #46
mrfred's Avatar
Originally Posted by itzwolf
I'm still slightly weary of the MAF scaling since I have never done it before... wish I had something to look at for a reference or close starting point. My X is my only car right now because my Evo 8 is down so I have to learn it and get it right the first time lol
i'm happy to provide the maf scaling i built for 3dman1's primo. pm me if interested.
Old Oct 11, 2011 | 08:30 AM
  #47
itzwolf's Avatar
I'd love to have the scaling, thanks so much!
Old Oct 11, 2011 | 08:44 AM
  #48
mrfred's Avatar
got ur pm. need your email addy.
Old Oct 11, 2011 | 08:48 AM
  #49
itzwolf's Avatar
doh!
YGPM
Old Oct 11, 2011 | 07:04 PM
  #50
tob11's Avatar
Im using a 3" Synaps intake with a 3a Racing dry pod filter. I dont have a heat shield (yet) but have installed the stock snorkle in its original place.
What i find is that while cruising, every x amount of seconds, the car starts to drift a little lean (say from 14.7 to 15.5) because its getting more air than its measuring, so it then corrects itself by pushing extra fuel through, then it ends up drifting a little rich and so on.
The lean out at 2-3k may be because at that particular partial throttle at low load, the maf volts DO need scaling as it is getting more air and its AFR effects are being amplified (this is beebles insight into the matter)
Old Oct 11, 2011 | 11:17 PM
  #51
mrfred's Avatar
Got some interesting logs this evening on 3dman1's Evo 10. A log of the stumble is shown below. Besides going lean, check out the ign timing being pulled. It really stumbles badly when this happens. What we found is that if it goes lean enough, then it triggers a misfire, and the ECU pulls timing even with no knock. I think the timing pull is taking place as part of the way the ECU is programmed to respond during a P0300 event. We aren't getting a P0300 CEL though, so I'm not sure by any means that this is it. I've got no time to go digging through Evo 10 code that I don't look at much any more, so hopefully tephra or others can find some time to take a look.
So we ended up dropping the open loop load down to 90. That pretty much took care of it. There is definitely something whacked with the way the ECU is calculating IPW in that ~100-120 load range during closed loop. It doesn't look to be MAF scaling because the MAF voltage rises steadily in this RPM range even though AFR is leaning out badly.
EDIT: Guess I'll mention that we changed MIVEC exhaust from -20 deg to -10 deg (-10 is stock) in the load/rpm range where the stumble occurs, and it did not lessen the stumble at all. We also logged MIVEC to make sure it was following the MIVEC maps, and it was.
Code:
Time	TPS	RPM	Load	MAFV	Boost	Ign	IPW	AFR	KS	STFT
22.444	53	2000	100	2.33	1.9	18	6.33	13.44	0	0
22.544	53	2000	101	2.38	1.94	18	6.38	13.23	0	0
22.643	53	2063	102	2.26	2.04	17	6.53	12.74	0	0
22.758	53	2094	103	2.34	2.24	17	6.65	12.48	0	0
22.859	53	2125	104	2.27	2.48	17	6.72	12.63	0	0
22.959	53	2156	105	2.39	2.57	17	6.84	12.69	0	0
23.059	53	2188	107	2.49	2.72	17	7.01	12.83	0	0
23.159	53	2219	108	2.6	3.06	18	7.14	12.86	0	0
23.272	53	2250	110	2.41	3.11	17	7.28	12.97	0	0
23.367	53	2281	111	2.43	3.4	17	6.72	13.01	0	-0.2
23.467	53	2344	113	2.48	3.54	17	6.3	13.02	0	-0.59
23.567	53	2344	114	2.62	3.73	17	5.86	12.82	0	-0.98
23.667	53	2406	116	2.69	3.98	17	5.39	12.95	0	-1.37
23.767	54	2406	118	2.67	4.22	17	5.39	13.48	0	-1.76
23.876	54	2406	120	2.84	4.61	17	5.72	14.3	0	-1.37
23.976	54	2438	122	2.81	4.65	17	5.78	16.41	0	-0.98
24.076	53	2531	122	2.62	4.8	13	5.86	17.14	0	-0.59
24.176	54	2406	123	2.47	5.04	16	5.97	17.33	0	0
24.276	54	2531	124	2.76	5.09	5	6.03	18.08	0	0.39
24.386	54	2375	109	2.7	4.31	17	5.86	17.42	0	0.78
24.486	50	2563	123	2.89	5.14	3	5.89	17.64	0	1.17
24.589	55	2594	119	2.52	5.62	17	6.46	16.8	0	1.76
24.685	59	2313	124	2.78	5.28	15	6.22	16.93	0	2.15
24.785	58	2688	127	2.95	5.86	1	6.5	16.86	0	2.54
24.900	58	2375	133	2.3	6.49	15	6.44	17.18	0	2.93
25.000	58	2594	131	3.05	5.52	1	5.68	16.61	0	3.52
25.099	57	2719	125	2.77	6.39	14	6.49	16.93	0	3.32
25.199	58	2281	134	1.88	6.06	14	6.23	14.92	0	3.32
25.299	59	2625	130	2.8	6.54	3	6.64	14.01	0	3.91
25.414	50	2781	134	2.69	7.02	17	9.59	17.65	1	0
25.514	47	2594	132	2.83	6.98	8	8.39	15.71	0	0
25.614	46	2688	132	2.69	7.36	17	7.9	13.8	0	-0.39
25.714	49	2688	133	2.76	7.56	17	9.35	12.88	0	0
25.813	49	2750	135	2.95	7.99	17	9.22	13.51	0	0
25.929	49	2781	137	2.95	8.47	17	9.38	14.19	0	0
26.029	48	2906	140	3.04	8.91	17	9.68	13.52	0	0
26.128	47	2875	143	2.96	9.25	17	9.8	13.48	0	0
26.229	47	3000	145	2.93	9.73	19	10.05	13.58	0	0
Old Oct 11, 2011 | 11:23 PM
  #52
tephra's Avatar
what am I looking at?
Old Oct 11, 2011 | 11:32 PM
  #53
mrfred's Avatar
Take a look now.
Old Oct 11, 2011 | 11:35 PM
  #54
tephra's Avatar
So your talking about ET 24.276?
How are you logging?
Old Oct 11, 2011 | 11:38 PM
  #55
mrfred's Avatar
Yes, and several other examples of timing pull in that log.
Logging with the latest beta of ATR.
Old Oct 11, 2011 | 11:52 PM
  #56
tephra's Avatar
ok...
why does the IPW drop at 23.667? the Load is increasing, so the IPW should also be increasing..
Old Oct 12, 2011 | 07:58 AM
  #57
mrfred's Avatar
ok...
I agree. IPW should be increasing. STFT shows the ECU switching from open to closed loop at 23.367 seconds. That's when fuel starts getting pulled despite increasing MAF voltage and load.
Old Oct 12, 2011 | 08:11 AM
  #58
itzwolf's Avatar
I know this is technically different but the timing being pulled comment sparked something I have noticed on upshifts and such which actually end up in this area we see lean issues also... I've been meaning to get some data to post up and see if others have seen it also. Anyway, I get a loud pop sound from my exhaust randomly. I originally thought it was a rich condition until I caught the ECU throwing negative timing at the car in this range when the condition happens.
I am guessing this is the fireball people seem to love so much but I dont care about and find it annoying as hell. I've seen up to -10 to -12 degrees in my logs when this occurs on the couple times I have caught it.
Anyone else ever experience this? I am thinking the max negative timing map will be the correction but I dont understand why the ECU would do this in the first place on a simple upshift... The map by default I think is -20 degrees across the board so I am thinking replacing it with the low octane timing map is the key.
Old Oct 12, 2011 | 08:13 AM
  #59
scheides's Avatar
EvoM Moderator
Man I am so glad others are seeing this, maybe we can figure out a real fix!
Glad dropping open/closed cutover helped mrfred, at least I am of some help around here... :P
Old Oct 12, 2011 | 10:25 AM
  #60
mrfred's Avatar
Oh, its definitely real, and you're plenty helpful around here.
ok, so here is the plot of the lean stumble. Easy to see that IPW starts dropping at the moment the ECU goes into closed loop. The ignition timing pull looks quite dramatic in the plot.
I continue to think the lean issue lies with the IPW calculation. Below is 3dman1's fuel map. Many people don't know that the fuel map is only used during open loop. During closed loop, the ECU automatically uses 14.7:1 as the target AFR no matter what is in the fuel map. So, what's interesting about 3dman1's fuel map is that in the 2000-3500 rpm range, I have to use very rich AFRs to keep it from going lean. There seems to be something funky the calculation in this rpm range. I'm not sure if people have noticed it, but the Evo 8/9 also has this same issue, but not as bad as the Evo 10.
Attached Thumbnails Lean-out issue around 3000rpm-er20_red_fic1100_e85_lean_stumble_plot.png   Lean-out issue around 3000rpm-er20_red_fic1100_e85_lean_stumble_fuel_table.png
