Advice on tune
Advice on tune
I have a 2010 gsR that I was thinking about using a Cobb tune on. It has a k&n typhoon intake kit,invidia exhaust, and I plan on adding a down pipe,hi flow cat, and licp before tune. My main goal is to keep the car reliable and smooth. I don't plan on doing any other mods besides this. Are there any other supporting mods I would need for a Cobb tune or would I be ok with that setup. Like I said I don't want to throw any codes have rough idle or have to worry about the reliability of the car. Also what are some realistic hp numbers with these mods. I just figured I'd ask before I proceeded. Thx in advance for ur replies
Did you plan on using accessport? If so, you should contact Cobb and ask them.
I think the maps for that device are off the shelf and may not be optimised for non cobb parts.
The other option is to get a custom tune, which will be tuned for the parts you have on the car.
Cobb could set you up pretty good I bet. Don't get the LICP. No Gains. It's the UICP or hot pipe on the Evo X that you need. Dpendng on Dyno I would say close to 300awhp on a Mustang Dyno. Very streetable for a DD.
Tuor
11
Jan 2, 2012 10:20 AM
