Evoscan software help
Old Oct 20, 2011 | 09:17 AM
maximus999's Avatar
Hi all,
My first post on here. Does anyone know much about evoscan software?
I have bought the software and cable for my mitsubishi shogun sport 2.5td. I ave successfully got it to connect to my cars ecu and the data is shown, the only thing is the data is way out. When i am at idle it is saying I am doing 220mph, also when i go to see any dtc it saying it cant connect, any ides?
I have contacted evoscan and there like taking forever.
Any guidance would be much appreciated.
I have added an attachment of the screen shot and hopefully yous can see it
Best regards
Old Oct 20, 2011 | 09:58 AM
Golden's Avatar
Select the CAN 2006+
Old Oct 20, 2011 | 10:15 AM
maximus999's Avatar
Thanks for that i will give it a try, do you know if there is any manuals for this software? there seems to be nothing i can find
Old Oct 20, 2011 | 11:10 AM
fostytou's Avatar
EvoM Community Team
Not really, but there are alot of tips around here and in the evoscan forums that Hamish hosts on his product site.
Old Oct 20, 2011 | 12:42 PM
maximus999's Avatar
Thanks for the help guys!
I have plugged it back in and the 'CAN' only highlights so i can select it when i select open port 2, i presume this is the cable, I only have 1.3 cable (hope I am right on this)
Anyways I have tried to see any dtc codes and it is saying 'no response from ECU' as you can see in the picture but it is connecting when in datalogger mode but all the paramaters are out and I am not getting any true readings.
The reason why i bought this is because I know mitsi dealers use MUT111 for diagnostics and evoscan has this facility, I want to see what boost I am getting from the car. I took her into the dealers who set the turbo up for me, they say it is running at around 190kpa which is factory specs, but on my boost gauge it is only reading around the 1.3 bar which is way below the 190kpa.
On the second picture iy is saying OBD11 sync byte not found and i dont know what this means.
I know my car is OBD11 compliant as I have had it on an OBD11 machine in the past and mitsi have confirmed my vehicle ECU can be read from it.
Attached Thumbnails Evoscan software help-kk.jpg   Evoscan software help-jjj.jpg
Old Oct 21, 2011 | 08:08 PM
Golden's Avatar
In the pull down next to the "Display DTC" button, you need to select "EVOX EFI"
Jim in Tucson
Nov 5, 2022 06:37 PM
golgo13
Feb 3, 2016 08:56 AM
JHS VIII
Mar 5, 2012 08:48 AM
EvolutinIX
Apr 5, 2010 12:11 PM
Vibrant
Feb 9, 2010 04:11 PM
