Split second power loss...CEL is now on. Ideas??
Old Dec 13, 2011 | 04:46 PM
flyinmonkey101's Avatar
I was accelerating in 3rd gear (90% throttle) and for a split second there was a power loss of some sort and the car bucked a little bit, almost like flooring it and taking your foot off the gas and immediately flooring it again. When it happened the CEL came on and is still on.
Any ideas? My only guess is its some sort of glitch in the tune or something.
Old Dec 13, 2011 | 04:50 PM
Kracka's Avatar
Step one: scan the CEL code and report back
Old Dec 13, 2011 | 04:55 PM
Well, it happened one other time a few months ago and the CEL flashed but turned off and ended up throwing an overboost code. I thought it was just a fluke. I have a feeling its a different code this time because it stayed on. I havent had a chance to have it read yet.
Old Dec 13, 2011 | 06:45 PM
tephra's Avatar
does you car idle funny?
Old Dec 14, 2011 | 06:14 AM
Not at all.
Old Dec 14, 2011 | 07:27 AM
oftheheavens's Avatar
sounds like a misfire. what are your plugs gapped at? have you checked that?
Old Dec 14, 2011 | 08:28 PM
Happened a month ago on old plugs and happened again with brand new plugs. They are new mitsu plugs. I didn't less with the gap.
Old Dec 15, 2011 | 03:52 AM
you should always check gaps. i have had stock plugs come with different gap sizes. not saying that is the issue, just a suggestion.
Old Dec 15, 2011 | 07:13 AM
Get Rad's Avatar
What does the CEL say? Do you know the code? You can identify the code by doing a little google search.
Old Dec 15, 2011 | 10:04 AM
johnnnyjeans's Avatar
you basically had a knock.
Old Dec 15, 2011 | 12:03 PM
fostytou's Avatar
EvoM Community Team
Check the CEL. If it felt like hitting a brick wall then it was overboost and you went over your boost cut/boost limit tables. If it broke up briefly (usually you will hear a few pops) it might have been a misfire, possibly from being too rich. It is getting colder, so it is not uncommon to have a little higher boost pushing you closer to the boost limit ceiling.
Old Dec 15, 2011 | 12:17 PM
drift collab's Avatar
Overboost. Possibly a bad/dirty MAF
Old Dec 15, 2011 | 07:56 PM
I'll clean the maf with maf cleaner. I'm going to have my tune looked at. The only difference is really the cooler weather so maybe that'd why it over boosted. When I fond out the code I will let you guys know. Tue higher flow exhaust probably isn't helping anything either.
Old Dec 21, 2011 | 09:41 AM
Hiboost's Avatar
Well if your load exceeds what was specified in the Boost Limits tables for 1000 ms it will cut fuel like that and throw a code. If the boost is climbing higher than expected I would get it reduced and possibly adjust the Boost Limits tables to be slightly lesss sensitive if boost is reasonable.
I have also had spark blowout due to being too wide of a gap once I upgraded my turbo, adjusting it down to a .022" gap usually takes care of that issue.
Who tunes your car?
*David*
50
Jul 15, 2017 10:10 AM
[p]dOG.
Oct 13, 2016 11:13 AM
Yorgis_MR
17
Oct 23, 2011 03:46 AM
phi79
10
Jan 25, 2009 08:16 AM
