Cant edit rom file
Old Jan 27, 2012 | 08:31 PM
GO ON 3's Avatar
Cant edit rom file
I can connect with my ecuflash but when I try and select from my drop down menue, I dont have options to edit settings?? Please help
here is a screen shot of what I get after I Download from the ecu
Old Jan 27, 2012 | 10:25 PM
GO ON 3's Avatar
bump
Old Jan 27, 2012 | 11:56 PM
AndyCT9W's Avatar
It appears you don't have the XML file to interpret the ROM. Try saving this file in your XML folder (rommetadata/Mitsubishi or something like that, it's in the ecuflash files).
http://code.google.com/p/ecurom/sour...pec=svn22&r=22
And then reopen your ROM in ecuflash.
I couldn't remember the exact location sorry, on holiday and I'm using my phone.
Old Jan 27, 2012 | 11:58 PM
AndyCT9W's Avatar
Follow the link, go view raw file and them go save as.
Old Jan 28, 2012 | 06:51 AM
GO ON 3's Avatar
humm for some reason that link doesnt want to load!
Thanks for the help, I'll see what I can do with this
Old Jan 28, 2012 | 10:02 AM
laksman91's Avatar
Just want to say, if you get stuck at this step - probably shouldn't be tinkering with your map files
Old Jan 29, 2012 | 12:27 AM
AndyCT9W's Avatar
Yeah, take it easy on your maps to begin with. I trust you've done a lot of research up to now.
You're after a 55570005 XML.
Old Jan 29, 2012 | 02:52 PM
GO ON 3's Avatar
Thanks Andy!!
Old Sep 5, 2019 | 09:39 AM
Llew's Avatar
What was the solution to this problem? Im having the same problem with my JDM evo x sst. Im able to edit roms on the evo 5 though. What am I doing wrong? Or are my setup files in Ecuflash messed up. Please help
evoxmel
Apr 26, 2017 05:37 AM
hanzo hasashi
Jan 2, 2017 03:11 PM
Do Work Son
Jul 28, 2016 08:42 PM
GTI.2.EVO
Mar 17, 2016 01:30 PM
03RRVIII
Jan 17, 2008 06:57 PM
