Speed density tune for EVO X
Old Feb 8, 2013 | 10:36 PM
  #31
Golden's Avatar
Originally Posted by itzwolf
Where can this patch be found/is it released yet?
I made one for the 2008. I obviously can find the addresses for any rom.
I ran it on a huge build type car. I know of at least another guy that has tested it on his stock like car.
Old Feb 9, 2013 | 10:21 PM
  #32
NZEvox's Avatar
About 6 months ago I destroyed my 4th MAF sensor ($749 NZD here :-( ) so in a fit of desperation I wired a 5k resistor in its place so the ecu sees 4.5 volts from MAF and maxed out the MAF tables , gave it a sd tune . It has been running faultlessly ever since. I wanted to make sure before saying anything .
Old Feb 17, 2015 | 06:19 PM
  #33
Justnii's Avatar
Can someone share this patch now please?
Originally Posted by JohnBradley
It hasnt been released as of yet. I dont really have a thread other than it does what the car does natively just all the time instead of based on MAF variables. The car earlier in this thread, Brent's, is the first one I have done and I have done 2 more since.
Aaron
I am hoping that someone can share this patch now, its ben a few years since its been released. I am currently running a full SD setup right now with the MAF tables maxed out. And the MAF still plugged by the wire but zipped tied to the side of the car. The maxed out tables and not hooked up MAF are causing the check engine light. P0101 MAF Error.
Thanks,
Justnii
Old Nov 18, 2015 | 12:10 PM
  #34
smoothgsr's Avatar
Justnii,
You need to place the MAF back on the velocity stack. This will removed the error code.
Old Feb 9, 2016 | 07:21 PM
  #35
NateDaJew's Avatar
^^^ did that work? ^^^
Gundamfan
Nov 9, 2017 09:16 AM
mines5
Jul 26, 2017 09:40 AM
DSMolition
Jan 8, 2017 12:51 PM
AWDTFTW
Apr 3, 2016 04:39 AM
evopwned
Mar 7, 2016 04:55 AM
