Strange CEL Codes
Old Dec 17, 2012 | 07:37 AM
Indianbrandon's Avatar
Strange CEL Codes
I have a 2008 MR afterflashing i recieve these codes:
~SST~
P0725
P1871
P1870
U0100
U0141 ETACS CAn Time Out
~AYC~
U0100
C1290
U3FFF
~MuT III~
P38E0 and/or P39E0
They all clear except the P38E0 always comes back on start up.
My Rom is pretty much stock with these exceptions:
Mode 23
Rear O2 Disabled
Slight timing change in mivec and afr
Car Runs and drives great.
I had flashed a more agressive mivec table and the car drove great had a lot more power on the low end. However with the more agressive tables when i tried to go wot at 3k to 5.5-6k it was great but around 6k the car would freak out and throw several codes and go into limp mode. Im thinking something to do with a torque limiter not sure though.
Any ideas as to what these codes are?
~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~EDIT~~~~~~ ~~~~~~~~~~~~~~~~~~~~~~~~
After reading i answered my own question only thing i dont know is why on start up i always get P38E0
Old Dec 18, 2012 | 09:45 AM
No matter when I flash the ecu even back to stock it seems I always get a variation of this code. P38E0, P39E0 P39A0. It clears but always comes back the next time I start the car.(Sometimes it takes a while for it to come on other times at start up)
It happend after i flashed for the first time. Which was also the first time that i Bricked my ECU. Bad luck i know all is well now. I also used the yellow wire for the rear 02 for my wideband.
Old Dec 18, 2012 | 04:33 PM
Octane Blue's Avatar
Are you using EvoScan 2.9? If so, that's why. The DTC are super gay. Try using 2.8 or PCM scan.
Old Dec 18, 2012 | 09:05 PM
Thats what Tephra suggested earlier today just got home from work downloading now. Hope this helps tired of this weird *** cel codes
Old Dec 18, 2012 | 09:19 PM
Does this program work with a tactrix cable? or do i need a different cable? Does the demo mode allow you to read codes or do i need to buy it?
Edit
NVM evoscan 2.8 worked. all is well now
sebass007
Lancer How Tos / Installations
40
Dec 28, 2020 08:20 AM
tuning g
Feb 27, 2020 09:09 PM
ApexVIII
Dec 15, 2015 10:45 PM
Egal44ARock
May 29, 2012 09:49 AM
