E85 the CONS!!!!
Old May 16, 2013 | 12:39 AM
  #46
RazorLab's Avatar
Originally Posted by Abacus
If you don't drive your car for 3-4 weeks it can ruin fuel injectors or cause flow problems. I would recommend running gas thru them if you are going to let the car sit or have them cleaned if they are out.
False.
I recently had my injectors set out to be flowed and cleaned. They have been in the car since 2007. They have had E85 running through them since 2008, so 5+ years of E85 usage. They also sat in the car for over a year, with the car NEVER BEING RUN that whole time. So sitting there with E85 in them, again NEVER starting the car for over a year. They checked out with flying colors, after seeing the report, I really didn't even have to get them cleaned. They where fine.
You can see the details here (and other E85 myth busters): https://www.evolutionm.net/forums/10784645-post67.html
Originally Posted by e_kobz
Yeah it will, it'll eat up rubber seals and o-rings.
False.
Proof: https://www.evolutionm.net/forums/al...years-e85.html
Old May 16, 2013 | 01:31 AM
  #47
Frogstofall's Avatar
Originally Posted by razorlab
False.
False.
I've read on another Evo forum about how E85 has the potential to ruin the delicate internals of some injectors due to its hygroscopic nature. While I'm sure its a rare occurrence, its certainly possible.
You are definitely in the minority. I've had E85 sit for just a month and throw my whole system off. Had to run gas for a week to fix that mess. All in all, I think E85 is worth the hassle if you have it in close enough proximity to where gassing up isn't a huge pain in the ****. Sounds like OP lives in E85 paradise.
Old May 16, 2013 | 01:55 AM
  #48
awdxftw's Avatar
Veteran: Army
False.
False.
super killer write-up man thanks a ton! Also good to see all the other people who's been running 85 for a long time w/ no issues like you too.
Old May 16, 2013 | 05:08 AM
  #49
Abacus's Avatar
[QUOTE=razorlab;10809017]False.
This was Razorlab's quote above. Not taking credit for any of his work. Thats a very well written thread.
Not trying to start a pissing match but we are in different parts of the country so there are a few variables. You're in California. First of all its the coast with the most and I'm jealous. Secondly, maybe the blend is different then over here in Fl. Lastly, we have higher humidity then you and that coincides with the rusted injectors that we've dealt with.
We've had trouble with one of the best injectors out there after sitting. This is on 3 different cars with one of them with a brand new fuel system. That guy's theory was that by going with a new system it would eliminate the possibility of old fuel/buildup clogging the system. We have also checked our fuel tanks and found milky colored debris in them after sitting for 3-4 weeks.
Also, all ethanol based fuels in the marine application have big issues here. So much that distributors are not selling it at most marinas.
Old May 16, 2013 | 06:26 AM
  #50
awdxftw's Avatar
Veteran: Army
[QUOTE=Abacus;10809117]
False.
yup your write-was nice to see charts to back up what your saying cuts the "I heard" out of the equation. Which brand injectors are you talking about that caked up in the 3 cars? You can pm me if you like.
Old Jun 1, 2013 | 07:20 PM
  #51
mufasa39's Avatar
Question Maps for E85
I only have a Cobb AP and have no idea what a map would look like, where should I start? I want to tune it myself but no start point. can anyone give me a clue bag to put clues into?
Old Jun 1, 2013 | 07:25 PM
  #52
FastAttack's Avatar
you need to have a protune on a cobb , so if your interested in doing E-85 find a protunner that has done a E-85 map and settings before.
If you were using a tactrix and open ecu it would be a tad easier, but I got a feeling your new to this game , so I highly suggest you seak out a shop or a tunner that has done this before.
Old Jun 2, 2013 | 11:02 AM
  #53
mufasa39's Avatar
E85
I do have ECU and EVOscan I just haven't pulled the trigger, Is it mostly in the fuel and timing maps? Golden will do it but I wanted to play with it first. Thanks for responding.
Old Jul 14, 2013 | 07:44 PM
  #54
Kendogg's Avatar
So how long is E85 good for? The E-85 gas station is not super close to my house so I was gonna buy a bunch of fuel containers and fill them up and use them as I need.
Old Jul 15, 2013 | 07:05 AM
  #55
cosmicblueGSR's Avatar
I may have missed someone posting this is the thread but just incase no one mentioned it, there has been a proven decrease in spark plug life after switching to E85. Be careful, make sure you stay on top of changing your plugs.
Old Jul 15, 2013 | 08:00 AM
  #56
Kendogg's Avatar
I believe Kracka said he changes his annually. Sounds like a good idea
Old Jul 15, 2013 | 12:51 PM
  #57
I believe i was told to change them every 2 oil changes.
Old Jul 15, 2013 | 01:33 PM
  #58
Kracka's Avatar
I'm on pump gas...just so we're all clear
That is wicked overkill. Annually should be fine as long as you avoid bouncing off the rev-limiter on a regular basis.
Old Jul 15, 2013 | 09:23 PM
  #59
My friends having problems with e85 on his evo 8 MR. He goes through spark plugs every 4000 miles and then i searched e85 spark plug choice on here and i found a thread that several people confirmed they have to change spark plugs every oil change or ever other oil change.
Old Jul 15, 2013 | 10:48 PM
  #60
fabcas311's Avatar
I have been using e85 for 4 years.... I tried to change plugs every other oil change, every 3-5k miles but everytime i pulled out the plugs they were fine!!!... So i agree annually unless you go to the track every weekend or race every stoplight! Lmao
