Cobb ap question.
Old Aug 31, 2013 | 09:53 AM
Whitey615's Avatar
Cobb ap question.
So I picked up an ap for cheap yesterday and was planning on flashing the cobb stage 1 map onto my bone stock 2011 MR.
My question is, do I need to watch for anything like knock or are the cobb maps fairly conservative?
I'm new to the evo scene but did have an ap for my wrx so I'm familiar with them.
Anything else I should know?
Thanks.
Old Sep 2, 2013 | 07:35 PM
fgafd2007's Avatar
I would like to know as well and can you tune the SST with the Cobb unit?
Old Sep 10, 2013 | 09:43 PM
Robstunner's Avatar
You should always do a log to make sure everything is running well.
Old Sep 14, 2013 | 07:40 PM
incognito7474's Avatar
If you have an AP and get the accesstuner race from cobb(free for personal use) there is sst tuning on it. i havent messed with it having a gsr but i still have the folders that's labeled SST on my accesstuner program.
Old Sep 15, 2013 | 06:27 AM
XGSR's Avatar
+1 for logging. I like to test the map for a few minutes before going WOT just to be safe. That being said I haven't seen more than 1 or 2 counts of knock since running their 93 octane maps.
Load the V400/V401, and prepare for awesomeness.
Old Sep 15, 2013 | 07:20 PM
Whitey615's Avatar
So I overboosted today and threw a p2006 code. Does not run well with cobbs 401 map. I uninstalled it today.
Old Sep 15, 2013 | 07:46 PM
XGSR's Avatar
They have a LWG map for that purpose. I'd be interested to know what causes that.
Old Sep 17, 2013 | 06:25 PM
Whitey615's Avatar
They don't have the LWG maps available anymore.
Old Sep 17, 2013 | 09:56 PM
ikt's Avatar
ikt
no way. I ran their maps and it made my MR run lousy, and a lot of guys reported a lot of problems.
Old Sep 18, 2013 | 04:49 PM
XGSR's Avatar
I'm not having any issues at all, mine runs like a top. They have several maps that aren't available publicly and must be requested.
Old Sep 18, 2013 | 05:32 PM
ikt's Avatar
ikt
mine just got worse today actually, misreporting datalogs to Virtual Dyno, crashed out, and the AP itself has a bunch of .log files in it full of squiggles and gibberish. Something about the latest firmware has just be chaos. The car runs fine, but can't tune.
Old Sep 18, 2013 | 06:12 PM
XGSR's Avatar
Are you on the general release firmware? Try the beta update if you can. Aside from that you could rock it as a belt buckle.
Old Sep 22, 2013 | 10:31 AM
IRPerformance's Avatar
What are your mods and what map are you running? In my opinion the Cobb maps are pretty conservative. You can gain an extra 10-20 whp with a custom tune, but its better to be conservative and safe. Make sure you are running a map for the exact mods mods you have. On my personal evo, the standard stage 2+ tune (turbo back exhaust and intake) would net 27 lbs of boost, which is a little too high in my opinion. I installed the LWG version, and it netted 25 lbs which is right where I wanted it. If you run something like the stage 2 tune and add an intake or intercooler, it will most likely overboost so make sure your tune matches your mods. Otherwise you will need a custom tune.
Old Sep 22, 2013 | 09:09 PM
ikt's Avatar
ikt
I'm on the beta yes
Old Sep 22, 2013 | 09:10 PM
ikt's Avatar
ikt
I never had a problem with Cobb on my 08, these problems have been chronic on the 2013 tunes, and my experience there is not unique. I have a custom tune now from Hollywood and it's fine, but still have problems with the AP reporting datalogs correctly.
jangempo
Oct 25, 2014 02:00 PM
Dmarianodesign
Jun 21, 2014 08:44 AM
The_X_Effect
Cobb AccessPORT
22
Aug 14, 2013 11:42 AM
GsrJake
Cobb AccessPORT
13
Apr 7, 2013 12:24 PM
Gstv
Cobb AccessPORT
Jan 25, 2013 08:38 AM
