new motor and still issues
Old Aug 28, 2015 | 03:43 AM
Blue_05EVO's Avatar
Long Long Long story short.
I just had a new AMS shortblock put in my x. and had a new fuel system as well including pump, cleaned lines, housing, ID 1000 and plug and play adapters, aem fuel regulator.
The car is going Lean on tip in !!!! and right as you take off from a stop!!
as you go into tip in it goes from normal 14.8-15.2 and then flashes 17.2 ish and then drops down to 12 is and pulls through the gear.
As I take off from a stop I also SOMTIMES go full lean for a split second before dropping back down to normal.
the car is on a break in tune and the tuner said that there is nothing in the tune that should be causing that. he said it must be something else mechanical or physically causing this.
Also I had this issue before my motor was replaced. just a lot worse.
ANY IDEAS ARE WELCOME! Again everything is basically new under the hood
Old Aug 28, 2015 | 04:11 AM
The Phantom's Avatar
What kind of mods are on it other than the short block? my only guess would be between pump and injectors. either pump isnt enough or injectors arnt. Are you able to monitor fuel pressure?
Old Aug 28, 2015 | 04:58 AM
Blue_05EVO's Avatar
DW65c with ID1000cc. Yes, AEM fuel regulator car holds base pressure at 41 and rises on a 1 to 1 ratio after boost.
Kerr
Sep 18, 2008 07:55 AM
jmsrx
56
Jul 9, 2008 06:50 AM
batty
Jul 18, 2004 06:51 AM
