Downloaded AccessTuner Race from Cobb... .exe file?
I submitted my application to Cobb with my details, and received their download file. I downloaded the link. However, the file is a .exe file, and my Accessport doesn't seem to allow me to use it. Any suggestions?
Correct. My apologies for not properly explaining. I could not get the Accessport Tuner Race file to sync up on my computer correctly. It wasn't reading the Accessport for some reason, and wouldn't load the program. I restarted the computer with the Accessport connected, and it seemed to process correctly. I now have both Accessport Manager open and running, as well as Accessport Race. (I previously used just the AP Manager and have a custom MAP loaded to my AP and Evo).
The issue I am having, and why I needed Accessport Race originally, is because my O2 sensor is setting off my Check Engine light consistently. I used the AP to reset a couple of times, but it only lasts about a day. I do have a 90 degree insert installed on the O2 sensor, supposing to take it far enough out of the flow that it eliminates the error. It does not seem to be working properly. I was told that Accessport Race would allow me to easily set this sensor so that it wouldn't set off my Check Engine Light. I searched through everything in AP Race, but can't seem to figure out how to do this. Is there anyone savvy in AP Race that can guide me through what i need to do?
ATR does not directly communicate with the AP. You make changes to your maps in ATR and then use AP manager to load the maps onto the AP. Kind of unclear what your issue is. The cobb maps are in a .ptm format so not sure what/how you're trying to load .exe files onto the AP.
Issue - Check Engine light is on because of the rear O2 sensor. (Running with test pipe)
Desired Solution - Trying to use ATR to program my Map to eliminate the rear O2 sensor, turning the check engine light off. I cannot figure out where in ATR there are any settings to adjust for this. I was told it was an easy solution in ATR.
Don't have it in front of me right now. But it should be under parameters or something along the lines. There will be checkboxes for codes. Check in the help file in ATR if you can't find it, it's pretty detailed.
FS[SouthEast]: Cobb Accessport V3 w/AccessTunerRACE.exe file
KRome
Apr 22, 2017 08:50 AM
RallySport Direct
Aug 27, 2008 10:21 AM
