Evo X fuel system diagram
Old Jul 17, 2017 | 03:47 PM
Lightsaber's Avatar
Post Evo X fuel system diagram
I recently found this fuel system diagram I thought I could share with you. If I understand correctly, the fuel tank is under vacuum, so any leaks would trigger a check engine light; Evo does not have a factory system to detect fuel line leaks, so we will have to be vigilant when smelling any gasoline around the car.
Overall the fuel system of our cars should be fairly reliable, right? At stock or bolt-on power levels it shouldn't have any risks to leak gas fumes or catch on fire?
By the way, for those unfamiliar with how any car's fuel system works, here is an explanation:
TwStDeVo
Aug 17, 2022 06:16 AM
SabrinaIX
Feb 18, 2011 06:42 PM
Evokid03
Oct 29, 2010 02:00 PM
Acree
Sep 2, 2010 01:57 PM
fe2o3
May 22, 2010 09:06 AM
