Does this log seem normal?
Old Mar 14, 2020 | 03:34 PM
craigebaker1's Avatar
I'm having trouble interpreting much in my logs from Evoscan. Can someone take a look and see the numbers look normal? For example, LTFT seems to only go between 0-4.41. Is that normal? The boost numbers are definitely not correct. Thanks in advance for any info.
https://datazap.me/u/obiwan/37?log=0...-34&solo=16-18
Old Mar 15, 2020 | 07:35 AM
crimson red's Avatar
I've never seen an evoscan's evox log with such item names(PurgeRelay? LTFT bank1? ETVIdleOpen? What are these??). Are these items created by yourself? If so, the addresses of these items are definitely wrong, so please correct it by yourself.
And normally, people take a log selecting the list that are preinstalled in the evoscan's 'Select ECU' dropdown to fits your evox's year and market(eg. 'Golden 2011 USDM v2 EVOX', 'RAX Fast logging - Rev E EVOX', etc). Is that not enough for you?
Old Mar 15, 2020 | 08:12 AM
You're giving me too much credit. I wouldn't know where to start creating my own logging items. This is straight out of the box setup. I have a 2014 USDM EVOX GSR. I've tried Golden 2013, RAX Fast, etc. But the only one that seems to provide numbers that are remotely reasonable is the defualt EVOX CAN MUTIII. So, If you have experience with the logs, can you at least look at the LTFT, STFT, and O2 and tell me if those numbers are remotely in line with normal, or if you see abnormalities. Just ignore the other items if you don't know what they are. Alternatively, help me figure out why I can't find an ECU in the list the provides normal output. Does anyone else have a 2014 that can provide feedback? The prior owner swapped out the ECU, so maybe it's for another year? I'll connect with ECUFlash again and see if it can help me identify the year of the ECU. Finally, I just bought the car and it has a LOT of problems, so I appreciate your patience as I try to unmask layers of issues and unknowns. If I could do it over again, I'm not sure I would purchase the car.
Old Mar 15, 2020 | 10:56 AM
I think that is possible. Can you save the rom by ecuflash and attach it to your post? That way we can see your current rom id. If you can't attach because it's a tuned rom, save the rom by ecuflash and check the id by yourself. The rom id is 4 bytes from 0x5002a. ( If you cannot read / save the rom with ecuflash, the previous owner may have tuned and the ecu is locked. )
I recommend RAX FAST LOGGING. To use this, you need to apply RAX Patch to your rom. Alternatively, logging in mode 23 is recommended. In both cases, you need to apply a patch to enable mode23.
Old Mar 15, 2020 | 01:39 PM
thanks for the guidance. Can I do all this with the fuel pump disabled? I have the TB and intake manifold off to make sure those gaskets aren’t leaking. Just found out they were brand new, so also wondering if I can tighten back down or if I need to completely replace now since I I tightened them.
Old Mar 15, 2020 | 02:20 PM
RazorLab's Avatar
What is your ROM ID?
Old Mar 16, 2020 | 09:13 AM
The problem with your log is simply that you haven't selected right item in evoscan's 'Select ECU', and probably you haven't set mode 23 to your rom.
There are two things you need to do:
1. Save your rom with ecuflash and check rom id. Then post the rom id, your evox market(USDM?), year(2009? 2010?). (If you cannot check the rom id, attach the rom to your post.)
2. Set mode 23 to your rom and flash(write) it to your ECU. (If you use RAX FAS LOGGING, also set the RAX Patch. These are required for logging with evoscan.
If you don't know how to do it, ask a question.
Old Apr 23, 2020 | 11:20 AM
Okay. Rax patches loaded and using EvoScan 2.8 for reading codes and v2.9 for logging. Please take a look at my logs below at idle. I have a wandering AFR problem at idle and cruise I've been fighting forever. I've replaced the front O2, boost tested, smoke tested, reran EBCS and WG lines, fixed exhaust leaks, checked fuel pressure, sent injectors to ID for cleaning and flow testing, cleaned MAF sensor, tightened fuel line connections, hmm, probably missing something but this is the majority of what I've done.
Thanks in advance for reviewing my logs and providing feedback!
https://datazap.me/u/obiwan/log-1586...5-6-9-17-25-30
Old Apr 25, 2020 | 06:33 AM
Should the TPS voltage vary at idle? Is that a factor of the AFR fluctuating? I would assume it's definitely not varying when the idle is stable is it?
Old Apr 26, 2020 | 06:20 AM
For the TPS issue, as far as seeing the chart, it seems to be related to the AFR issue.
It is possible that there is something wrong with the throttle body, unstable TPS might be the cause of unstable AFR.
Did you check or replace your throttle body?
Old Apr 26, 2020 | 09:31 AM
I recently took the throttle body and intake manifold off to inspect for leaks. I cleaned the throttle plate, but probably not thoroughly. I'm going to replace the intercooler pipe that connects to the TB this week and will inspect and clean the TB at that time. What should I look for that could be failing on the TB?
Old Apr 27, 2020 | 03:13 AM
Please be careful. The throttle body of evox is electronically controlled, so basically it cannot be cleaned.
I've heard that if someone who doesn't know how to clean an electrical controlled throttle body clean it, it can be destroyed.
Looking at your chart, what seemed to work with AFR was STFT, not TPS. (I misunderstood the color of the curves.) As you mentioned the TPS continues fine vibratation. The STFT looks normal as long as seeing its curve.
Old Jun 30, 2020 | 11:58 PM
veiri86's Avatar
Am not an expert, I had similar issue when I cleaned my Throttle body and it acted up for sometime till I realized I have to do the throttle body relearning procedures, check this thread
https://www.evolutionm.net/forums/ev...lls-start.html
maximusnz
Jul 30, 2012 08:53 PM
05blue8
Oct 13, 2010 08:10 PM
Nevonate
Sep 12, 2007 10:32 AM
