Coil pack #1 not getting power causing misfire
Hello couple weeks ago my 2015 Evo 10 started misfire so I changed the spark plugs . Misfire stayed so I changed the coil pack . Misfire is still there so I tested the coil packs on a piece of metal and cylinder one gets no spark(cylinder #2 does ) so I switch coil pack 2 with coilpack 1 and cylinder #2 still gets spark , cylinder one still doesn’t . I tested the connector (to the coilpack ) and it has power . Wtf is the issue . Really need help on this one cause it’s not making sense (also I compression tested the car and numbers are perfect )
SterbenSchwien
Oct 10, 2019 01:42 PM
Randal
Sep 1, 2013 04:21 PM
